Window doesn't roll down when window down button is pressed - can manually push window down but it drops into the door - seems off the track.
Chicago, IL, USA
Pretty much the title.
Sometimes when I press the up button the window goes up but I typically have to manually push the window up and press the up button to lock it in place. Doesn't seem like the common window switch issue in the forums. Is there some way to get this thing back on the track or did a clip break or something.
Apologies if this is a repost.
The Window motor is most likely given up the ghost. Get the entire assembly/ motor and regulator if possible. You can test the switch also with a multimeter to rule it out also. What year & mileage?
W
Chicago, IL, USA
17 with 30k
