Part Number for Rear Hub Assembly Bolt
Anchorage
Hi, I was going to install rear camber plates, and the bolts that attach the hub assembly to the rear beam appear to be torque to spec and single use- does anyone happen to know the part number?
Thanks!
Pablo Pistoffo
Anchorage
Erick_V
Texas
Good to know. They're pretty cheap so I'll probably pick them up for piece of mind.
aaronraad
Logan
Any idea what the part number is for the two threaded locating pins between the mounting bolt holes on the axle bracket?
