Hey guys I just installed a used x47 turbo and I have 0 boost. The turbo makes like a whirring sound. It sounds like its spinning up without any back pressure. I reset the tune and I’ve checked all the boost lines everything seems fine. Any ideas on what it could be?
 Based on your boost gauge, it looks like your engine is pulling a vacuum though your turbocharger's compressor (located in your air intake system).
The compressor of your turbocharger is powered by your turbocharger's turbine (located in your engine exhaust system).
Pull off your air inlet from your turbo and your down pipe. And inspect both compressor and turbine wheels. Also confirm that your compressor wheel turns as you manually turn the turbine wheel.
PS: Confirm you are getting oil though your turbo oil lines and water though your turbo water lines (if equipped).
