Feisty the "Family Car"
San Diego
Glad to hear! I will say that when I was running the B6/Rally springs, the combination of ride height and stiffer spring rates definitely helped a lot with both ground clearance and rubbing, but also paradoxically, ride quality because I wasn’t bottoming into the front and rear bumpstops literally all the time. The stock setup engages the nose of the front bump after only 1/2” of compression and the rear bump soon after. The nose of the bumpstops are soft so they act like a spring aid for the first inch or two, but it also means that they ramp shortly after that and produce uncomfortable jolts.
If you do try the rally spring setup, I’d love to hear feedback as so far I haven’t seen anyone else try it (or at least none commenting)
Thanks for all the great and consistent feedback! I have a couple more questions!
How do you think the stock 14-16 (or 17-19 even) springs would work with the B6s? Seems like you mentioned that a few times. I'm assuming the ride height would be exactly stock height?
Second, any idea if the rear shocks that come with the B14 ST kit (labeled F4-BE3-G752) are identical to the B6 or B8 fiesta st rear shocks? After an accident, the body shop installed a B6 on the side that got hit, so now the part numbers are mismatching and I don't know if the damping rates are the same...
thanks!
Dialcaliper
Dialcaliper
San Francisco Bay Area
Thread Starter #144
thanks!
The B6’s were originally designed to be stock replacement (with stock springs), so they should work fine.
The B14 rears are the same shock body, but the damping is lighter than both the B6/B8 and even the stock Ford rear dampers. I believe they have a shorter shock shaft like a B8, so that will affect droop height
Unfortunately they are not the same damping at all. Your choices are probably these:
1) Install a second B6 to match and see if you like the end result or not
2) Contact Bilstein (aftermarket in So-Cal) and let them know about the accident and ask if they’ll sell you a single rear B14. You might need to send in the wrecked B14 if the shop didn’t throw it away
3) Ask Bilstein instead if they’ll either revalve your B6 or sell you a B6/B8 revalved to the B14 damping spec. However, I believe the B14 has a shorter shock shaft similar to the B8.
4) pick a still different rear damper for both rears (maybe a KYB or Koni adjustable) and match the original damping as best you can
Testing courtesy of @Fusion Works
https://www.fiestastforum.com/threads/bilstein-science-experiment.29105/#post-482235
San Diego
I believe that some of the vendors will sell you a single B6 damper.
But most likely none would sell an individual B14 damper. [:(]
I'll give them a call tomorrow and see what they say.
Yeah it makes sense that the shocks that come with the B14 are different than the B6, since the ride height is minimum 1" lower.
I'll probably end up buying another B6 rear and then trying out stock spring since they can be gotten for free or cheap and maintain stock height.....
Dialcaliper
Dialcaliper
Thread Starter #147
If you’re keeping the B14 springs in front, stock rear springs will be too soft to keep up, and you’ll get some uncomfortable pitching behavior regardless of the dampers you’re using. Either keep the B14 rear springs as long as they still have enough preload to stay in place, or else swap in some similar rate 2.5”ID coilover springs in the rear along with some helpers - if you keep the Bilstein adjusters, a 4k or 225lb/in 7” long spring plus helpers, or if you remove the adjusters, a 200lb/in 10” spring (like the one I spec’d for the rally spring setup) plus the helper will be stiff enough.
Unless of course you plan to swap back to stock springs and B6 struts all around
Fusion Works
Huntsville, AL, USA
I would even tell you to run the B6/B8 damper on the rear compared to the B14 rear damper.
Bilstein probably won't sell you any parts from the B14 kit. All of those kits are made in Germany and US really has little input into their design. I am trying to get the adjustable shafts from the B16s but Germany is not cooperating with me. I am not supposed to be building shocks, cuz I am a hill billy, not a pure German certified Shock specialist. US Bilstein Motorsports can't even get these parts.
San Diego
Not gonna lie, I'm not doing any gravel/dirt driving, so yeah, I'm most likely gonna end up with stock springs and B6s and call it a day!
Dialcaliper
Dialcaliper
Thread Starter #150
What year is your car? Ironically one of the reasons I ended up pursuing the “rally” springs idea is that it was remarkably difficult to locate a set of Pre-2016 springs 🤦
Even if you were going to do some low(er) speed, gravel/dirt driving, that combo would handle it just fine, even with the post early '16 build springs.
My car with full factory suspension (LATE 2016 build, so yeah, softer spring rates) was kind of amazing at handling even the worst of the gravel stage rally roads I drove on when working/volunteering on ARA rallies. [thumb]
San Diego
i have a 2018, but a local guy here in SD is selling me his 2015 springs, because he wants to tinker with your 10" rally spring idea. Win-win for all! He is a lot more interested in track driving than I, which means he has a great way to test suspension setups too! Anyway, if he finds some amazing combination of spring/damper, I might move to that in the future, but for now, I need the more compliant street setup for the sh*t streets we have here in SD.
Montreal
Great read as always. Why did you choose tender springs VS helper springs? In page four of this thread, you explain :
The heavy tender/assist spring is tuned to give adequate preload, and a dual-rate like behavior in droop to help with shock extension on rough back roads, but will be fully bottomed at static ride height.
Does this mean that swapping to helper springs (which have a negligible effective spring rate) in a setup like yours would :
1- Not give adequate preload
2- Not help the shock extension on rough back roads?
Krackenamg
denver, co
Around November, I decided that I was tired of pushing the button to disable the rather invasive ESC every time I got in the car, and after poring over the wiring diagrams and the internet, by January I'd finally located all of the components to do a custom auto-button pusher! Since I'm running a tune and it doesn't matter as much, I configured it to turn on "Sport Mode" 30 seconds after starting the car to avoid the occupying the Sync with the progress-bar for "ESC-off"
At the same time, I took the opportunity to pull wires and correct some questionable wiring the previous owner did to install the little Kenwood Sub under the driver's seat, by installing terminals in the engine fuse box
I've done a full writeup on both.
Auto Sport Mode Module: https://www.fiestastforum.com/threads/diy-fun-mode-automatic-sport-mode-esc-off-circuit.30262/
Fusebox Guide: https://www.fiestastforum.com/threa...erminal-part-numbers-no-more-fuse-taps.30228/
great job done there..
Dialcaliper
Dialcaliper
Thread Starter #155
Helper springs fill function #1. Which is adequate preload to keep the springs from falling out.
#2 is where having a heavier helper spring may help. Once the weak helper is no longer fully compressed, both the spring rate and the total extension force provided by the spring can in some cases not be enough to keep the wheel in contact with the ground as you go across a dip, or come off an abrupt hump and actually catch air if only very briefly. If this happens while cornering, a wheel not on the ground is literally a wheel that can’t provide lateral force any longer.
Under extremely hard braking coming off a rise is another case where the rear wheels can lift, causing instability, zero braking contribution from the rear wheels and possibly some pucker-worthy sensations from the drivers seat.
Montreal
Also, I managed to get some new corner weights for the car…at the dump! Dropped off the coolant at the recycling center and they had a scale - it wasn’t busy, so the attendant let me take a couple of measurements. Managed to get the whole car, the rear axle, the right side and the right rear tire and still see the scale readout. Between those I worked out the individual weights. The scale seems like it was pretty repeatable and probably decent to 10 pounds, as they actually charge by weight for big dropoffs, as I got same value for the left front by calculating it out both ways.
Between the new brace and skidplate, the spare tire and my roadside bag in the back, a mostly full fuel tank (instead of ~1/4 like last time), and the new shocks/struts which are significantly heavier (but lower unsprung weight being inverted), the car came out 100lbs heavier than last measurement. (2940lb With 150lb me in the car). Also, somehow I lucked out with a 50.3% cross weight just by eyeballing the left front adjuster, and choosing the “slightly shorter” eBay spring in the right rear
Based on the measurements, it almost looks like I could stiffen the left side springs a bit. I think I’m going to play with some spring rubbers on the left front, and maybe go to a heavier spring or rubbers on the left rear. Making right and left frequencies more closely matched should help some of the side to side “rocking” over bumps (although the sway bars are also responsible for some of that.)
Once I have the setup close to final and the shocks back from FCM, I should probably get a “real” corner balance and alignment at a good shop, just to verify my “shade tree” alignment measurements aren’t too sloppy. Also, need to make up a real toe gauge. Two tape measures flopping all over the place is getting annoying, and setting up the string box takes a bit of time to get right, especially if adjustments need to be made
I actually just did this on mine, albeit with a different method.
Full stock interior (with recaro), full tank of gas, essentially daily driver configuration. 2014MY with sunroof. 185/60/15 winter tires with 15x6 OEM ford steelies. Koni orange dampers all around, stock 2019 springs. Stock exhaust.
Front
Whoosh v3 intercooler
Suave 4point bar
Ramair crossover pipe
Whoosh hotside pipe
Butyl 80mil sound insulation in front doors
Rear
Half-size steelie spare tire
Mishimoto rear brace
10 lbs roadside kit emergency bag (right rear of trunk)
Full trunk (but not hatch) butyl 80mil sound insulation
It's also an interesting way of seeing the difference in droop travel from the front to the rear.
Using an Amazon 660lbs package scale and with this beam method, I was able to measure with a (+-5lbs) accuracy each corner of the car.
Here is an example:
You can see that the front left corner with no driver in it is 407.1lbs. After the driver and the driver+pass measurements, the scale showed 418.0lbs, indicating a shift of 10lbs, (so +5lbs). I averaged both these results. This indicates a good +-10 lbs of potential variance for each axle (after timing the result by two, per the lever arm).
Did three measurements, empty, 160lbs driver and 160lbs driver + 160lbs passenger. Here are my results. You should apply a +-10lbs measurement interval for each corner, and in total, a +-40lbs interval for the total weight.
The beam method is not as accurate, but it seems that my measurements are in the ballpark of your yours. The only notable difference would be the left front & rear distributions.
Dialcaliper
Dialcaliper
Thread Starter #157
After driving the car around for a few months on the new suspension, the ride height settled out about 0.75” below stock height, with the adjusters almost bottomed out.
Took a few hours on a weekend to raise the adjusters up 0.5” per corner to sit just below stock height.
Also it’s been cold, rainy and I’ve been driving on dirty roads so plenty of gunk built up down there. Needs a wash. I’ve getting a funny spring clunk in the steering and occasional windup in the springs, probably to do with not having a real top bearing - the upper front perches are fixed and while I have swift spring couplers plus some thrust sheets up top, the lower perches is the just spring ion anodized aluminum which might be the source of the behavior. Now that I know I have 0.5” of downward adjustment, I may start thinking about some sort of more robust sealed needle bearing at the lower end.
While I was at it I took the opportunity to replace my windshield trim that was decaying. One of them was literally falling apart in my hands trying to remove it. Took a week to get that crap out from under my fingernails 🤢
Dialcaliper
Dialcaliper
Thread Starter #158
Got serious and finally did a brake (and clutch) flush with ATE200 brake fluid. Added stainless lines while I was at it. There's a slight difference, but very subtle and could just as well be the new fluid rather than the brake lines. Ran 2 whole liters of fluid through the system.
Ended up buying a power bleeder, and making 4 of my own brake bleeder bottles with 1/4" silicone tubing, some juice bottles from work, some cheap 1/4" PVDF check valves, and some silicone bottle clip rings I found on ebay, with a little wire to hang them. Ended up being a huge help since to do it right, you need to bleed with Forscan.
My neighbor gave me some surplus surgical drapes that I cut up and put to good use here to keep from spilling brake fluid everywhere.
Word for the wise, if you do a pretty thorough brake flush by cycling the ABS unit, hook the car battery on a charger. The ABS unit draws a ton of current, and if the accessory voltage Forscan is seeing drops below 10V, it aborts the test. I'm glad I had the check valves in the bleeders, as the last flush stopped in the middle!
Dialcaliper
Dialcaliper
Thread Starter #159
Also spent the $40 to upgrade my Dizzy Stage 2 tune from V2 to the new V3. It does feel like there's a little bit more grunt across the rev range. But the most immediate difference is a quality of life one. Jason did a really good job this time dialing the off-idle and on-off pedal transition. The previous tune was decent, but the car feels so much smoother without the tiny lurch when you go from throttle to coast, or get back on the throttle. Like butter.
Got out for a drive in the hills today and between the suspension adjustment and the new tune, it's starting to feel pretty awesome! Definitely happy about how the whole build has been turning out. Finally feel like I'm ready to sign up for a track day (change some more fluids - the Amsoil is finally getting close to the 25k mile mark).
The new tune also makes a better showing in V-Dyno. For some reason Jason's tunes previously always tested out low unless you get the car on a real dyno so the actual difference is smaller. I started adding TC Slip Actual to the datalog and it gives another obvious sign on whether you took a good datalog or not. Seems like a good run mostly stays below 2% slip. A bad run you'll see spikes >>2% Here's the new (V3) vs old (V2). These are not SAE corrected, though I do have the temp/pressure numbers. Similar conditions (a bit cold), and same stretch of road (although in opposite directions - the same direction data log had a big slip, so basically invalid.
Burlington, NC, USA
Awesome to see. I loved Jason’s flash tunes when I was running the stock turbo and he tuned my big turbo like a champ as well.
