Air inlet door not moving. Double click every few seconds
Recently replaced all my AC actuators. Everything has worked fine the past 200 miles up until yesterday. I started hearing a double click like click click every 5 seconds. I removed my glove box and noticed the air inlet vent wasn't moving so figured the actuator broke. I replaced it and it still doesn't work. I then disconnected the actuator and I still hear a constant clicking every 5 seconds whether the AC is on or off and no matter how long I drive. I checked the fuse for climate control and ac clutch in the passenger and engine compartments. Not sure what this could be?
SteveS
If it's the one by the glove box there is a procedure to make sure the motor (gear) is indexed correctly and the flap valve is in the right position before you put it in. Did you do that?
WolfDampf
No I thought if it lined up and went in I was good lol. What's the procedure exactly?
WolfDampf
Scanned codes with FORScan and found in the HVAC module B1A61 Cabin Temperature sensor. Additional fault symptom circuit short to battery or open. Here is a YouTube video I recorded of the click sound it makes even when I have the actuators disconnected and the AC off.
SteveS
I can't remember exactly but it was on a piece of paper in the box with the actuator. The flap in the airbox had to be set one way and there was a notch on the actuator to line up before inserting it.
WolfDampf
The incar temp sensor is a part that's kind of in the way when you replace the actuator on the drivers side. Maybe you unplugged it? It's a cylindrical thing that sticks into a hole in the center console or left side of the dash.
https://www.tascaparts.com/oem-parts/ford-in-car-temp-sensor-3m5z19c734c?c=Zz1ib2R5JnM9Y2x1c3Rlci1hbmQtc3dpdGNoZXMmbD0zJm49U2VhcmNoIFJlc3VsdHMmYT1mb3JkJm89Zmllc3RhJnk9MjAxOCZ0PXN0JmU9MS02bC1sNC1nYXM=
I never touched it but Ill try reconnecting it and inspecting. I'm really hoping this is something simple the click is non stop every 5 seconds whether I'm using HVAC or not and having it stuck on recirculation sucks
