Air inlet door not moving. Double click every few seconds
Houston, TX
Recently replaced all my AC actuators. Everything has worked fine the past 200 miles up until yesterday. I started hearing a double click like click click every 5 seconds. I removed my glove box and noticed the air inlet vent wasn't moving so figured the actuator broke. I replaced it and it still doesn't work. I then disconnected the actuator and I still hear a constant clicking every 5 seconds whether the AC is on or off and no matter how long I drive. I checked the fuse for climate control and ac clutch in the passenger and engine compartments. Not sure what this could be?
SteveS
Osage Beach, MO, USA
If it's the one by the glove box there is a procedure to make sure the motor (gear) is indexed correctly and the flap valve is in the right position before you put it in. Did you do that?
WolfDampf
Houston, TX
No I thought if it lined up and went in I was good lol. What's the procedure exactly?
WolfDampf
Houston, TX
Scanned codes with FORScan and found in the HVAC module B1A61 Cabin Temperature sensor. Additional fault symptom circuit short to battery or open. Here is a YouTube video I recorded of the click sound it makes even when I have the actuators disconnected and the AC off.
SteveS
I can't remember exactly but it was on a piece of paper in the box with the actuator. The flap in the airbox had to be set one way and there was a notch on the actuator to line up before inserting it.
WolfDampf
Houston, TX
The incar temp sensor is a part that's kind of in the way when you replace the actuator on the drivers side. Maybe you unplugged it? It's a cylindrical thing that sticks into a hole in the center console or left side of the dash.
https://www.tascaparts.com/oem-parts/ford-in-car-temp-sensor-3m5z19c734c?c=Zz1ib2R5JnM9Y2x1c3Rlci1hbmQtc3dpdGNoZXMmbD0zJm49U2VhcmNoIFJlc3VsdHMmYT1mb3JkJm89Zmllc3RhJnk9MjAxOCZ0PXN0JmU9MS02bC1sNC1nYXM=
I never touched it but Ill try reconnecting it and inspecting. I'm really hoping this is something simple the click is non stop every 5 seconds whether I'm using HVAC or not and having it stuck on recirculation sucks
WolfDampf
Houston, TX
Inspected the cabin air sensor. Nothing strange just a bit of dust I blew off with air and reconnected. I tried installing a new AC actuator and the issue is still persistent. When I start the car the AC door closes to recirculate and when I turn off the car it opens up so it's definitely working. Not sure why I can't get it to open and close on command and why it's making this clicking noise every 5 seconds....
Is this the part which makes that rapid fire clicking when it goes bad (or is about to go bad), sitting behind that circular vented bezel on the right side of the steering column??
WolfDampf
Houston, TX
Yes. But mine hasn't been making any noise at all. Even so I cannot find why I'm hearing this click click noise and since I do have a code for the air temp sensor I'm going to try replacing it.
Good news is I disconnected and reconnected the actuator and now my air inlet vent works on command again! So everything works perfectly fine now but I still hear this click click every 5 seconds the entire time HVAC on or off! Driving me insane
