Oil pressure/temperature guage
Italy
Hello, was just wondering if it was worth installing an aftermarket oil pressure/temperature guage?
As the car does not have either. Would this be worth the investment? I have the fear of my engine overheating lol
Thanks for any feedback.
Mesa, Arizona, USA
I would personally be more worried about the coolant temperature... you could purchase a COBB accessport and use that to monitor certain temperatures and variables, including coolant temperature. You can use that without modifying the car to fit an "aftermarket gauge"
M
Italy
Iv upgraded the radiator (airtech), the thermostat (motorad) and replaced the temperature sensor.
Was just wondering if the oil pressure/temperature are worth monitoring. I will be installing a new oil pressure switch. Just wanted to know if its worth adding the guage.
Grsemky
U.S. Navy Veteran
Arizona
Peace of mind is worth a lot, however a oil temp gauge isn't really needed on our engines... The filter is attached to a cooling block and has lines that exchange temp with the coolant. If oil temps start climbing, so will coolant so that track that🤷🏼‍♂️
