Gauging interest in a run of budget big brake kit brackets?
Are you interested in a set of brake brackets?
  • Hell Yes, I’ve got $400 burning a hole in my pocket
    Votes: 11 50.0%
  • Likely someday, but I’m not ready to put money down
    Votes: 9 40.9%
  • Nah, I’m fine with but this looks cool
    Votes: 2 9.1%
  • WTF?
    Votes: 0 0.0%
  • Total voters
    22
Dialcaliper
Dialcaliper
Thread Starter #21
My CFO (aka my partner) has checked my math and called me out on raising the price being unfair, so I'll hold the $375 price for any additional sets. However, I will only be ordering either 10, or as many additional sets as I have invoice that I'll have sent out by tomorrow morning (sorry weekend folks getting quoted the exact number of additional sets for tomorrow, as I got the kibosh put on for ordering a couple of extras just in case someone misses the window)
I want to apologize to everyone for jerking around and changing dates and prices. Also to the mods because I still haven't figured out or gotten a response on how to properly handle this as a FS or GB post and what forum rules this falls under. This order snowballed from mild interest a month ago to "figure it out urgently!!"
After Friday morning, that will be the end of this order. If more people are interested, I can collect names, and if I get 10 additional folks with money in hand, I may consider kicking off another order at some point in a more "group buy" style, but I'll have to set the price at $450, because the margin came out a lot slimmer than I was expecting once the total cost is rolled up and I also didn't raise the price after including the ARPs (oops). Or maybe figure out if its possible to get @ron@whoosh involved, as he's got a platform and much more experience with this kind of thing
No apologies needed and definitely don’t let us hustle you along. It’s not like you’re getting rich on these and you did literally all of the leg work.
Dialcaliper
Dialcaliper
Thread Starter #24
The 10 sets are now claimed, I’ll be finalizing the quantity with the machine shop by 12pm (pacific) today to keep the delivery on time.
If you’d like to get in on the order and recieve an invoice, I need to know by then (Name, Email/PayPal info and shipping address for the invoice) via PM
Dialcaliper
Dialcaliper
Thread Starter #25
FYI order is now closed and I’m giving the go-ahead to the machine shop.
If you missed out and would like to be on a wait list in the event that I look at making another batch, let me know
Dialcaliper
Dialcaliper
Thread Starter #26
Just a small update. Will post once I have an update from the shop on delivery
I’ll be working on some installation instructions as I have time in the coming weeks.
In the meantime, before you rush out and buy parts, these are the correct part numbers for the Boxster “non-S” calipers. Check before you buy as occasionally they’ll be advertised as the wrong type on eBay
The “Porsche” part numbers and Brembo part numbers are embossed in the castings as shown in the photo.
Porsche 986.351.421 (Brembo 20.6672.03)
Porsche 986.351.422 (Brembo 20.6672.04)
Incorrect part numbers are very close, so check carefully, ideally in photos of whatever you are buying.
- Incorrect “S” front calipers carry very similar “996” part numbers (996.351.425/426) Boxster S are painted red, but the base 911 uses the same caliper which are grey, Brembo part contains “7069”
- Incorrect non-S Rear calipers end in “423” and “424” (986.351.423/424). Casting numbers are also usually on the underside of the caliper and also carry “6679” Brembo part numbers
- Incorrect “rear” calipers from 986 Boxster S and 996 911’s have very similar numbers beginning in “996” instead of “986” and Brembo numbers containing “6679” (996.351.421/422) and can be red or grey. These maybe actually the same as the non-S rear calipers, but are still wrong
Dialcaliper
Dialcaliper
Thread Starter #27
You can find any old seal kit out there, but some “recommended” ones are:
Girodisc ($56 for one caliper) https://girodisc.com/caliper-rebuild-kit-for-porsche-987-cayman-s-36mm-40mm/?
Racing Brake ($146 for the pair): https://racingbrake.com/search-results-page?q=bp-402
The racing brake kit also has a high temp dust seal option for a little extra, and the stainless pistons for a lot extra (which don’t allow the stock pad dampers to be used, so expect some extra pad noises/squeal if you leave them out)
Gonna ask the stupid question
Looks like most of the used sets on eBay are around $500 in decent condition, some a little more some a little less. Will end up right around $1k with the stainless piston rebuild kit.
Don’t know anything about the factory dust seals or pistons, but just curious - Do you think $1,200 brand new calipers from Porsche would be better or worse than a rebuilt set with stainless pistons and high temp seals?
because i want to paint a set of porsche calipers blue and put them on the party car? and i like projects.
Yeah either way mine will immediately be sent for high temp paint, I’m more curious about expected performance between factory new and rebuilt with stainless pistons. I realize this is a theoretical question. I’m a dummy with brakes, just want to do what’s more likely to keep me from going face first into the tire wall.
Dialcaliper
Dialcaliper
Thread Starter #31
I guess I didn’t include that option given the “budget” theme. The stainless pistons and high temp dust seals I opted for are “theoretically” better thermally from an “heavy track use” standpoint. The dust seals in particular will stand up better to high pad temperatures. but for street use they won’t make any difference, and with the stainless pistons you lose the ability to use the pad dampers to reduce brake pad noise.
As long as the calipers look in decent condition and aren’t seized, fresh seals and boots make them pretty close to new. Most Boxsters are usually pretty well taken care of right up to the point of being binned
You can get what look like new calipers from FCPEuro for just under $600 each, so yes that is a viable option
https://www.fcpeuro.com/products/po...er-front-right-boxster-cayman-por-98635142203
https://www.fcpeuro.com/products/po...per-front-left-boxster-cayman-por-98635142103
Grsemky
Brakes are extremely simple, it's just transferring the force of the pedal to the rotors using fluid as a medium... So long as the seals are quality and no scoring or nicks in the piston, there's no difference between rebuilt and new calipers
#33
For anyone interested, brand new calipers from FPC Euro came in at $1,253 out the door
Dialcaliper
Dialcaliper
Thread Starter #34
Awesome partial update! The machine shop delivered a little early, so I have the brackets in hand! I’m going to start working on packing them up to ship this weekend and will hopefully get most of them out this coming week, along with finishing the instructions!
Stay tuned!
#35
#36
I’ve been looking at FCP Euro for the front pads. But really want the info on where to order Glocs for a Porsche.
Porsche brake pads
SVT rotors
Already had power stop blanks front and rear which were ~200 shipped from Rockauto.
I run those EBC rotors on the OE brake setup for daily duties & consider them a waste of money.
Dialcaliper
Dialcaliper
Thread Starter #37
Porsche brake pads
SVT rotors
Just call up GLoc directly and ask for base Boxster (GP737 shape) pads in your choice of compound and they’ll either send them if they stock them or just make them to order. That’s how I ended up getting mind. They are quite helpful over the phone. Direct price is not any different than through their dealers.
Plain brake rotors are your best bet. Slots and holes are a relic of the 1960’s and pretty much cosmetic at this point. Some full on racing/time trial pads can still benefit from slots in higher tier racing circuits that still require iron rotors, but anything you’d put on a car for HPDE or amateur racing, all you’ll get is faster brake pad wear and lighter wallet.
From Rockauto works, or Tire Rack if you want to get the cryo treated Centrics and they have them in stock
Here’s the first draft of the installation instructions that I’ll be including in the boxes:
https://docs.google.com/document/d/1JX_3qSzn2eDi1MWOM6iNlXHahfoaB7VjRRQl-9dP3T0/edit?usp=drivesdk
Let me know if there’s anything you think I should include
#38
@Dialcaliper - We're fortunate to have you here. I'm not in on it, just posting an appreciation.
I'd be in if they were to work with Stockers! But i know i can wish in one hand and poop in the other and see which one fills up first! [drummer]
Post a link to spacers that folks can purchase to go with his BBK kit.
