How-To: Stock Height Rally Performance Springs for OEM/B6 style suspension
Dialcaliper
Dialcaliper
San Francisco Bay Area
Thread Starter #41
Here's a pic.
I'm a bit concerned by the front ride height. Seems like it might be getting lower. Left side may be slightly lower than the right. I wonder if the cheap springs I used in the front aren't very good.
The rear seems a bit higher than OEM. I'm tempted to cut a bit of height out...
Agreed, the rear looks close to factory “new” which if you look around online is the tire “centered” in the curve of both fenders. Your front is definitely low, but that just depends on personal preference of where you want it to sit
All springs will settle initially after a few hundred miles. Even my custom Bilstein setup built with entirely Swift springs settled between 1/2”-3/4” in the first month.
London, ON, Canada
#42
I installed a set of these spring spacers in the front https://www.amazon.ca/gp/aw/d/B07WGF224D/ref=ox_sc_act_title_2?smid=A3BEBWTOARC1WU&psc=1
It definitely raised the front of the car back up about 1" which is where I'd like it to be. I think on smooth roads it rides better, I suspected it was sitting on the bumpstops before.
I'm not sure if the first spring loop at the bottom is considered a fully "active" spring. If it is, I assume I increased the spring rate by 20-25%. On rougher roads the ride feels harsher. I haven't had a chance to push it much in corners yet.
London, ON, Canada
#43
I think I'm happy with the cheap spring spacers. I think i like the way the car handles now. Ideally, I'd like the ride to be a bit better, but it's about where it was when I had the Indy 500 tires on stock springs, as opposed the ECS 02 now.
I'm not sure my variation of dialcaliper's recipe with front springs from cheap aftermarket R56 rear springs, cut slightly, with spacers , is one I can confidently recommend to all, but this kludge solution seems to work. Part of me wonders if the springs I used are of OEM quality.
SVTBob
U.S. Air Force Veteran
Arizona
#44
Not as knowledgeable as some of the responders, so I followed Dialcaliper’s recipe to the letter. Have had them on for several months and several thousand miles using very low mileage OEM struts and shocks. In about 20k, will replace with B6’s. But have to say, that even with the stock struts/shocks, the ride is much more compliant and pleasant, especially over sharp road defects, and I have not noticed any deterioration of handling in aggressive street driving. So, for me, DialCaliper’s objective has been totally realized and I thank him again for his effort to do this to start with. And I strongly recommend this to anyone with a stockish FiST as a great improvement in increasing the enjoyability of the car on the street.
portland, or
#45
It’s time to give these springs a final report card, and I think they deserve an A+
The car has been handling and surprisingly,
riding slightly better than stock on the stiffer springs - probably because they don’t bottom on the bumpstops nearly as often
I’ve run them on the car for a year and a half, and a bit over 11,000 miles, and they’ve held up well. The rubber gasket rings I added as spacers still look almost new even though I was worried about them.
Then springs didn’t really settle that much, but if anything they look even closer to stock than before. Aside from being a bit dusty from driving on dry dirt roads, they held up really well
I’m finally moving onto my fancier customized Bilstein suspension now that it’s finally ready, so these are being retired. Not sure whether I’ll keep them as spares or just find a new home for them.
Thanks for the writeup, I'm doing my own research to essentially do the same! If you decided you want to sell that setup, I'd be interested in the parts and/or full damper setup.
Dialcaliper
Dialcaliper
Thread Starter #46
I’ve actually passed it off to someone I know locally, but happy to answer questions if you have any!
SVTBob
Arizona
#47
Gargamel, if you’re intimidated by the write up if you’ve not done this before (as was the case with me), just do it. Buy the parts in Dialcaliper’s recipe, take your time, follow the instructions and refer to the pictures and I think you will find that it is actually pretty easy to do this. I am very happy with this setup, a big improvement.
portland, or
#48
That's great to hear the positive feedback!
One question before I go about it, based on the feedback ""The 3” spring is about 1/8” too small for the top hat because of the taper on the stock plastic bearing so it won’t sit all the way “up” on the flat. Ideal diameter for the spacer is about 3.25”""
I am able to find 3.25ID coil springs with a useful spring rate for the front. Landrum brand. Would you advise going with 3.25 if available - or stick with the 3" since the spacer means it doesn't matter?
10" ones on this product list from Landrum. Found em at Summit.
Dialcaliper
Dialcaliper
Thread Starter #49
They might work, hard to say. The one thing to watch out for is that the extended length of the strut from perch to perch is slightly over 10” (about 10-5/8” from plastic bearing to lower spring perch ). So just a 10” spring with no spacer at all might end up being a bit loose in droop (and also your ride height might be affected by the same amount). The spacers serve kind of a dual purpose in both getting the spring below the wider diameter, and also ensuring the spring is actually preloaded slightly in full droop so it doesn’t rattle or shift.
Also, the ends of the stock springs are barrel shaped and actually 3” ID. The reason the coilover springs a slightly too tight at the top is that the OEM springs are “pigtail” ends, and the coilover spring is a closed, full round flattened end.
London, ON, Canada
#50
My use of super cheap R56 rear springs in the front didn't work out. I ended up getting some 3.75" ID x 10.5" length 250lbs/inch springs. They sit slightly off center on the strut. There's a piece of metal that sticks up on the bottom of the strut and the spring sits against it with the OEM rubber isolator in between. The OEM spring end rests against this piece. I'll have to see if this works out. The front wheel gap currently sits 0.5" higher than the rear, but I'm uncertain if it's finished settling. It currently handles nicely.
I suspect a 3.25" ID spring would be fine, but given my track record, I'm not sure if I'd recommend others believing me.
BrendenN
Squamish, BC
#51
I'm still reading through all of this so apologies if my question has already been answered somewhere in here. Amazing work! much appreciated that someone has taken the time to figure this out and also test the setup. In all of your searching have you come across a setup that would be similar to as described but perhaps slightly higher than stock ride height? I'd like to gain a little clearance on the car. I realize this would also raise the Center of Gravity making the car more tippy but where I live it would definitely be beneficial to have a bit more clearance
Dialcaliper
Dialcaliper
Thread Starter #53
You can either increase the spring rate a bit to lift the car up.
FYI as a reference point, a base model Fiesta is 0.25” higher in front, and a whopping 0.9” jacked up in the rear compared to the ST, so there’s room to go up a bit especially in the rear without compromising suspension geometry. The OEM ride height spec in the service manual is also stated that +/- 0.5” F/R for the ST is still considered “in-spec”
