Overheated today, suggestions?
Hello everyone,
Today while on the way back from lunch I hear the chime, see the red temp light, and the coolant temp boxes maxed out. Car went into limp mode, was able to get it off of the highway and into a parking lot. Ran for maybe a minute after being alerted. I opened the hood and noticed that the coolant expansion tank hose was dripping, coolant levels were a bit lower than the minimum line, another concerning thing was the bubbling coming into the tank from the line that was leaking. Once I got the accessport plugged it was reading temp of 245.
I let the car sit for about 10 minutes and decided to see if I could get the temp to come down with the help of max defrost/heat. This worked and the temp slowly got itself back down to 190’s. I cleared the codes (overheat, limp mode, and something about the cylinder head temp) so that I could get out of limp mode. The weird part about it was even though it was on defrost with max heat the air was still coming out ice cold. It wasn’t until driving 10 minutes that the heat came on full blast. The car would also bounce between 180 and 190 and when I got up to highway speed the temp would skyrocket again to 210. The car drives fine, no smoke, no smell out of the exhaust, idles fine. Oil looks like fine, coolant looked fine, tiniest bit of air coming out of the tank when I put my hand over it while running but I feel like that’s normal as the coolant circulates?
Is that coolant tank likely the cause of the overheating because it was low and maybe developed an air bubble or should I be concerned for the headgasket?
About the car:
MY16, mountune rad, last fluid change summer of 20 with 70/30 motorcraft coolant/distilled water. Full bolt on, E30 tune. No recent mods done other than replacing my old coilovers.
Where it was leaking until it got below that level:
E
Erick_V
I was hoping it wouldn’t be the thermostat or pump. I think I’ll likely buy the reservoir, water pump and thermostat in case the tank alone doesn’t fix the issue
Cneu
That's funny, i literally just had this problem a few days ago.
MIne never got to the limp stage, but I noticed a few weeks ago that my defrost wasn't exactly hot. I had a very, very small/slow leak from the turbo coolant hose. I had a bubble that settled in my heater core so my heat wasn't working. At first I thought my head gasket had blown, lol.
That stupid connector piece. It got brittle and fell apart the second I touched it.
I was unable to find the connector piece as a stand alone part. It seems there are some china-sourced ones but the ship time is insane and they might not be correct.
What I wound up having to do is visit a couple of local ford dealers to get the correct part, which is C1BZ-8B081-?. There's a question mark because there are variations on this part, depending on the model it goes into. The 8B081 is the base part number which you'll see in parts diagrams.
Whoosh sells it here, https://whooshmotorsports.com/products/motorcraft-engine-coolant-reservoir-hose-2014-2019-fiesta-st if you have time to wait. I didn't, which is why I drove around for 3 hours to find the correct part.
Replacing the part is super simple. It's a foot of hose with a clamp on the far end, then you just shove the connector in to the reservoir. There's one guidance clamp on top of the engine.
If anyone is reading this and their fiesta has 100k miles on it, you should have this part on hand because that lil piece of plastic is going to fall apart on you. When it does there is no easy fix. It sucks. This is something that I would "upgrade" to a more standard connector if I had more time. Just a simple hose clamp makes more sense, idk why ford did it the way they did.
E
Erick_V
I ended up buying the whoosh coolant reservoir kit and it comes with the hoses. Looks like I got all the right parts and am picking up the motorcraft coolant and distilled water today. Luckily I have a second vehicle to use. Funny you say anyone over 100k should replace this, mine failed at 103k! Thank you for the reply
Cneu
lol yeah im usually pretty hesitant to straight up say "this was a dumb decision" cuz im an electrical/mech engineer, so I get it, but this is really one of those things that I looked at and just thought "heh..what?"
My only idea is that this has to do with the suction that happens when the car gets turned off. But I still don't get understand the need for a narrow ass piece of plastic in this circumstance instead of just making the hole on the reservoir smaller. Maybe something to do with siphoning pressure or something.
