Hey All. I've wanted one of these for years and finally decided to pull the trigger to teach my son to drive manual and how to work cars. Grabbed a completely stock 2017 with 161k on the clock that happened to be in the area a few weeks ago. Runs great, but needs some cosmetic love (definitely involved in a front end collision, and some idiot drilled holes to mount an autozone hood scoop). Besides the bumper brackets being broken, found the radiator support was broken in numerous spots, the welds on the cross piece that the rad support and crash sensors mount to were broken, and the driver side fender rail apron was a little smooshed, and the lower mounting tabs on both headlights were broken. Repaired the apron, replaced the rest, massaged the bent portions of the hood back into place, and everything fits together passably. Plan is to do autocross periodically, which includes a 170 mile drive to/from the closest club, as well as an around town beater. Currently fixing to install the eBay GPI radiator, a replacement overflow tank, get some correct sized tires, replace the front pads/rotors, and replace the AC blender motors.
Only issue noted so far (besides overheating after a spirited drive followed by dead stop traffic): At idle it started stutter/drop down to nearly stalling and pick back up. I read all of the threads regarding this after re-fueling, it started happening on less then a half tank so doubt that's it. Probably going to convert it to a 14-15 evap harness anyways so that is a problem for another day.
Previous cars: 91 Stealth TT, 05 Evo VIII MR, and currently daily a 2020 F150 Raptor.
