New FiST owner
sdelivery
U.S. Air Force Veteran
Del Rio, TX
Hey All. I've wanted one of these for years and finally decided to pull the trigger to teach my son to drive manual and how to work cars. Grabbed a completely stock 2017 with 161k on the clock that happened to be in the area a few weeks ago. Runs great, but needs some cosmetic love (definitely involved in a front end collision, and some idiot drilled holes to mount an autozone hood scoop). Besides the bumper brackets being broken, found the radiator support was broken in numerous spots, the welds on the cross piece that the rad support and crash sensors mount to were broken, and the driver side fender rail apron was a little smooshed, and the lower mounting tabs on both headlights were broken. Repaired the apron, replaced the rest, massaged the bent portions of the hood back into place, and everything fits together passably. Plan is to do autocross periodically, which includes a 170 mile drive to/from the closest club, as well as an around town beater. Currently fixing to install the eBay GPI radiator, a replacement overflow tank, get some correct sized tires, replace the front pads/rotors, and replace the AC blender motors.
Only issue noted so far (besides overheating after a spirited drive followed by dead stop traffic): At idle it started stutter/drop down to nearly stalling and pick back up. I read all of the threads regarding this after re-fueling, it started happening on less then a half tank so doubt that's it. Probably going to convert it to a 14-15 evap harness anyways so that is a problem for another day.
Previous cars: 91 Stealth TT, 05 Evo VIII MR, and currently daily a 2020 F150 Raptor.
Mesa, Arizona, USA
Welcome!
First, I would highly recommend an aftermarket radiator.
Second, rather than converting the evap harness, you could just cut the current setup up so it's easy to replace the purge valve. (replace the hard lines before and after the valve with hoses and worm clamps, might be 3/8in ID or smaller, I cannot recall, but that's how I have mine set up)
S
sdelivery
Del Rio, TX
Welcome!
I went with the all aluminum radiator from eBay (linked from someone else's post, fairly sure its a mishimoto clone). The stock one is the smallest I've ever seen. Im fairly sure my motorcycle radiator holds more coolant.
Thanks for the tip on the purge valve lines, that route sounds significantly more cost effective.
Mesa, Arizona, USA
If you are wanting to go aftermarket on an intake/crossover pipe where it goes to the one port, you will need to convert to the 14/15 harness. If you stay stock (which the stock intake works well enough), you can keep it as is. I bought a super cheap purge valve from eBay, tossed it on the car maybe 5-10k miles ago, and it's been great since. Was like $15.
S
sdelivery
Del Rio, TX
The plan for now is stock. Will take a look for the ebay valve, though even the OEM valve itself is only 27$, way better than 200+ for the whole set up.
Grsemky
U.S. Navy Veteran
Arizona
I have a GPI radiator from eBay and it's performed flawlessly here in the desert. I think I hit 209⁰ after idling for 20min with ac in the school pickup line
Cneu
Hillsboro, Oregon, USA
I have a triple pass mountune rad. I dont think mountune is necessary, but a better radiator is if your car is unfortunate enough to have heating issues. Some of these engines just like to get a bit hot. I didn't realize mine gets hot until I was in California/Arizona/Nevada and it was 110F. I kept overheating on any decent hill. Triple pass rad took care of that for the most part.
Radiator install should only take an hour or two, it's relatively simple. Fitment can be a lil tight and moving the A/C lines can help. Be aware that whenever I touch my cooling system my A/C stops working for a day or two. No idea why, lol, but it can happen.
Since yours gets a bit warm, I'd also pay attention to the coolant bypass valve on the head. They're known to fail and will throw codes, plus you'll overheat. It only opens under certain circumstances, so the code might not show itself until you're driving up a mountain in california like I was. The coolant bypass valve is the black/blue valve by the harmonic thing on the front of the engine, just behind the rad on the right side. Look for the lil blue thing. I had to swap mine out in Lone Pine, CA in 110F+ temps in the napa parking lot with a broken/bloody hand. It was not fun.
S
sdelivery
Del Rio, TX
I too daily a Rap and have a FiST. My fun car is a first generation CTS-V. Where in the armpit of Texas are you? I spend time in Lone Star for work but live in PA.
lovely Del Rio. If you’ve never been, don’t 😂
The Rap is my fun car lol, though I was toying with picking up a ct5v Blackwing.
S
sdelivery
Del Rio, TX
Do you remember what codes per chance? I threw a p1450 and 1299. Just assumed both were related to it overheating
Cneu
Not off the top of my head. The code is directly related to the valve, though, so you'll know if you google them. P1450 is fuel system bleed related. P1299 is head overheat protection, so you should pay attention to that one.
