BOOST ON S280 TURBO
Noosa, Queensland, Australia
Hi everyone, i would like to hear back from ppl running the s280 turbo, how much boost do you run? What sort of power you making and do you still run the stock map.sensor and t sensor ( the one in the cold side pipe) ?
Cheers
Grsemky
U.S. Navy Veteran
Arizona
Don't get mislead into boost numbers, they're not everything see, to give an example a larger turbo can output more air at a lower psi than a smaller turbo at higher PSI.... Not to mention our cars are tuned but torque demand and that will change from engine to engine and environmental factors. A better question is how much power are you looking to make?
F
360/370bhp
Grsemky
U.S. Navy Veteran
Arizona
I'm not big turbo yet, but I feel the S280 will be on the upper end of it's limit for that level of power... I myself have my eye on a GTX2860, which can supply that level of power easily! Though I'm looking for 3-330whp with room to grow when I get bored of the power
Maryland
Loaded question. Fuel? Supporting mods? All that affects the amount of boost you can run. With fuel mods and E55 I'm running 28psi. It's most I would do on the stock block if you want it to last. You can have more fun at 32psi, but it won't last for too long. Search the S280 thread where there is tons of info.
Burlington, NC, USA
Ethanol is really the key to power with this car. On 93 you’re going to make 275-285whp no matter what bigger turbo you pick. S280 can make 320-320 on ethanol and a bit more but you’re really pushing the turbo there. I have an s280, gtx2860 and a g25-550. Currently on the 2860 making right around 300whp on straight pump e85 and can’t imagine wanting any more power. Already traction limited on 215 wide 615k+ tires. They grip on the track when warm but for street driving temps there’s nothing you can do to stop them wanting to spin. ~28-30 psi is the sweet spot on the 2860 and g25. I haven’t ran the s280 since upgrading the fuel system for pump e85, but it was around 28 as well.
Grsemky
U.S. Navy Veteran
Arizona
How does the 2860 compare to the g25? I've been leaning towards that direction
I would think it was gonna make the car perform more like a tuner car not really kicking in hard till about 3500 rpm. It’s true in these cars the sweet spot is around 285 whp-300 whp. at those numbers you will get some TQ steer. Once you start going over that you wind up with a car that’s hard to drive on the street IMO . Though with the bigger Turbo which will spool later you could drive around out of boost and will be kinda slow🤣
The S280 in my eyes is a great street turbo for our cars . It might kick in a few hundred revs later than a Hybrid but it’s quite linear on pump gas which makes it pretty drivable. On a e30 tune it gets back the crazy TQ bump bottom end kick you would see with Hybrids.
Grsemky
U.S. Navy Veteran
Arizona
The S280 in my eyes is a great street turbo for our cars . It might kick in a few hundred revs later than a Hybrid but it’s quite linear on pump gas which makes it pretty drivable. On a e30 tune it gets back the crash TQ bump bottom end kick you would see with Hybrids.
Yeah the boost curve will definitely be moved, but the G25 is supposed to be extremely efficient and will be making 16psi around 3k... I normally drive a stock turbo limited to 15psi so a larger turbo flowing more air at the same PSI should be pretty peppy on the street
16 psi on a FiST at 3k is not going to have a lot of power . FiST’s live stock at 21-22lbs. .
Our engines do not have really how flowing heads and Ford tweaked it for the car and relies on high pressure to overcome that. In essence 16’s psi on a Fiesta is nothing power wise. If you drive your FiST at 16 psi. you are dog slow.
Running a larger turbo at that number will produce nothing power wise on our engines.
Grsemky
U.S. Navy Veteran
Arizona
You're mistaken on boost and air flow, a larger turbo will flow more air at a lower boost levels, yes our tiny turbos needs lots of boost to make power because the volume is small...
Look into the head design what I am talking about with our engines is a reality . I am not a newbie to these cars I am an older school member who has come back to visit . I ram a very well tuned s280 car for several years and sold it.
Grsemky
U.S. Navy Veteran
Arizona
Then maybe you should go back to school for physics... Head flow will impact flow rates, which increases pressure... However that's irrelevant to the conversation, a larger cross section(big turbo) will flow more than a smaller cross section! To give an example a 1.75" hose would need 35psi to match the flow rate of a 2" hose at 20psi
