Review/Install of NAV-TV Backup Camera.
#41
Did you guys ask about the FiST to be sure it would work as the listing specifically states it works with the 8" screen?
A question that was asked by a customer and the answer says if it has the 8".
Maybe it is just the camera that is different?
I am waiting to see how this works out as well.
Sorry your back has been acting up, I have had far more than my share of back pain, not fun in the least, glad you are getting better.
Rick
CanadianGuy
#43
[MENTION=879]D1JL[/MENTION] I know this is an older post. Just wanted to check in if the nav-tv software for the back-up camera is still working as advertised after sync updates.
Thread Starter #44
Yes,
It works perfectly.
Dave
#46
Damn!
I have been wanting a back up camera at a decent price that works really well, seems this is the absolute best way to go but I have spent a few more thousand on the car lately and still have a few things to order.....when you get this installed and it works right I will just have to bite the bullet and get one as well since I now use the car on the street quite a bit it is a must have form me.
The price is much better now, Dave paid a bunch to test this out, thanks for doing so, hope this way of doing it works as well!
Rick
jayrod1980
#47
Wonder if it will work with sync3 system since it's totally different
#48
The 25OFF promotion is back on at autotoys ... too bad it doesn't apply to international shipping and cost an additional $65 shipped to Canada
CarGuy
#49
Still awaiting results from the other backup cam systems the 2 guys bought...
Unfortunately, mine is still NIB, and still on the todo list.
#51
I was considering going with the MyTouch 2 LockPick. I am going to add a sub as well and like the idea of using it for line level out vs tapping a speaker wire. I emailed coastaltech support and they indicated my 2015 was supported. But the above referenced deal at autotoys seems pretty solid as well.
Sent from my VS986 using Tapatalk
CanadianGuy
#52
Ok somebody other than Dave get one installed!!! I don't mind doing this but getting it to Canada is a PITA so want to see it work one more time before I commit. Either option look good to me.
#54
I attempted it with the ntv-kit 456 I bought from [MENTION=411]westcoaST[/MENTION] with no luck. I wired it up and plugged in the programmer and got nothing on the screen. I'm assuming this is because mine is a 2015 and the nav-kit says 13-14 but I'm going to call them on Monday to see if I did anything wrong.
CanadianGuy
#55
13-15 are all the same. Sure the camera works? Does the screen change when you place the car in reverse?
#56
I installed the wiring harness and temporarily wired in the camera just in the cab. The LED lights on my camera worked. I went to plug in the programmer and nothing happened. No black screen. No booting screen. Got a green light on the programmer box for about 3 seconds but only if the car was on and running and even then still nothing on the screen.
CanadianGuy
#57
Well the instruction says once the harness is installed start the car and the screen should be a normal screen. Are you getting this? Then, with car on, connect the programmer. Curious if you have a tune? Maybe it needs to be factory map (i doubt it).
Link to the instructions
https://navtv.com/media/products_file/2015/01/12/My_Ford_Touch_CAM_rB9.pdf
CanadianGuy
#58
Also read this part of the instructions
NOTE: BEFORE THE MYFORD TOUCH PROGRAMMER CAN BE USED ON ANOTHER VEHICLE, THE
ORIGINAL VEHICLE MUST BE UN-PROGRAMMED.
The MYFORD TOUCH CAM PROGRAMMER WILL NOT UN-PROGRAM ANY VEHICLE IF THE
VEHICLE WAS ORIGINALLY PROGRAMMED WITH ANOTHER PROGRAMMER, INCLUDING
FACTORY PROGRAMMING, OR A DIFFERENT MYFORD TOUCH CAM PROGRAMMER.
2. Connect the white/blue wires TOGETHER.
3. Repeat steps 2-5 under the Programming section, above
#59
I start the car and get my normal display. I plug in the programmer and nothing happens. I do have a tune but I also tried un marrying my accessport completely. Didn't change anything.
#60
I was told that it was never installed however I also tried to jump the two wires as stated with no affect.
