BOOST ON S280 TURBO
Noosa, Queensland, Australia
Hi everyone, i would like to hear back from ppl running the s280 turbo, how much boost do you run? What sort of power you making and do you still run the stock map.sensor and t sensor ( the one in the cold side pipe) ?
Cheers
Grsemky
Arizona
Don't get mislead into boost numbers, they're not everything see, to give an example a larger turbo can output more air at a lower psi than a smaller turbo at higher PSI.... Not to mention our cars are tuned but torque demand and that will change from engine to engine and environmental factors. A better question is how much power are you looking to make?
F
360/370bhp
Grsemky
Arizona
I'm not big turbo yet, but I feel the S280 will be on the upper end of it's limit for that level of power... I myself have my eye on a GTX2860, which can supply that level of power easily! Though I'm looking for 3-330whp with room to grow when I get bored of the power
