Blow off valve not shut during low throttle
I VOTE for replacing the connector! Time to test out your Electric repair skills!
Agreed. If the gasket/harness is damaged, then water will infiltrate, the pins will corrode, and the connection will begin to intermittently fail; resulting with symptoms that may trick service personnel into incorrectly replacing hardware. If he glues it, (depending on how,) the wires will need to be snipped next time it needs to be taken apart for service. It'll also serve to prevent a prolonged session of cursing from the unwitting service personnel.
C
CaptainHummus
U.S. Air Force Veteran
Seattle
Thread Starter #22
Where would I look for the OEM BPV connector? All I am seeing online is the entire wire harness and I only need the small plastic wire connector
Dialcaliper
San Francisco Bay Area
You’ll have to hunt down the actual connector unfortunately. The part number referenced is only the complete engine harness
Here’s the Motorcraft pigtail catalog where you might be able to find it
https://www.motorcraft.com/content/.../wire_sets_wiring/18376-Pigtail-Book-2016.pdf
Images of wiring guide attached
A lot of the connectors in the Fiesta are manufactured by TE - I’ve had a little luck using Google image search to identify a couple of them, but it’s a bit of a needle in a haystack.
AA7D1EC0-C672-48A7-BE17-24FA000EB67A.jpeg D0E6124B-A9AC-4915-8E36-B53B5AC5699F.jpeg
C
CaptainHummus
Seattle
Thread Starter #27
Thanks for all your help you guys. I think it will be okay if its not water or heat resistant; I can always use tape or some kind of covering to protect the connector from the elements and the engine heat. Ill do some digging around and if worse comes to worst I can always epoxy it if I cant find the part
