Can't find new flywheel
San Jose, CA, USA
I'm looking for a new flywheel but I can only find part C1BZ-6477-C and the oem part is C1BZ-6477-B. The tasca website says this part should fit fine, but I wanted to double check on here before I buy it.
Northern Virginia
I have used C1BZ-6477-C twice now with no problems. I never even knew there was an alternative.
I recommend calling before ordering, as the flywheel can sometimes be iffy on availability; you don't want to order online just to be in limbo for a month.
ron@whoosh
Vendor
Las Vegas
we have them in stock
from what I could tell we snagged the last 8 that were available
although you may find some at local dealers if you call around
Saint Pauly
Those are called supersessions* It is what most manufacturers do when they do quality management or make slight changes if any to the part. Both part numbers will work just fine*
