Can't shift into reverse
Stoney Creek
I need help. I just got to work and while parking I couldn't shift into reverse. All gears work fine, however when I pull up the ring to shift into reverse, I can't shift. I can shift into every other gear with ring up except reverse with engine off and clutch in.
No mods except camera and subwoofer.
Any ideas?
EDIT: works now. I took it apart and everything seems fine.
Jabbit
New England
Pull up the shift boot and see if there is something obvious that isn't engaging with the lockout mechanism. Otherwise sounds like you are pulling through parking spots for now. Still under warranty?
Ralf
Stoney Creek
Thanks for quick response. I will check that out in the evening. Hopefully I will be able to figure it out. If not, pulling through parking spots for coupe of days will be my new specialty.
