Dual catch tank ....is it needed?
Am new too the fiesta just picked up my 17 and got RMM,
So my next mod on my list was the catch tank.
Doing some research and found some vendors offering the catch tank kit that goes between the PCV system. And a second setup that goes on the driver side by the intake tube.
So is both needed for good protection from oil re entry? Or is it just for highly modified HP cars
thanks
Rivy
Sorry I don't have an answer, but jumping in to see what folks have to say. I have no real plans for a catch can, but have seen some folks talk about them being pretty beneficial.
I have always heard on here that the second, NOT PVC side catch can/air-oil separator is only an absolute necessity on VERY high boost, BIG TURBO, crazy high power setups (like 350+ to the wheels).
I have the Damond OCC installed on the PCV side of my stock/factory setup engine, and it is perfection (drain about an ounce or two of thin, fuel smelling, liquid out of it about every 2K miles or so, which otherwise would be going into the intake tract, and possibly depositing/baking onto the backs of the intake valves). :)
As I have always said...Something is better than nothing......[wrenchin]
KnockOff
I also use a catch can and I did the math. At just 1.5 oz every 5k miles that's 27oz of oil I prevented going into the intake and on the back of the valves. Very conservative math. So you be the judge.
I am trapping much more than 1.5 oz of liquid every 5k miles with my Damond OCC, just like M-Sport Fan said above. If you buy a Damond, spend the extra 10 bucks for the hose sleeves.
Rivy
Good info, I see Damond, what other brands are recommended? How easy is the install?
KnockOff
I just installed a damond about a month ago with hose sleeves and a vta on top. I will see if it catches more than the mushimoto I had soon enough.
DAMOND....end of story...easy install...rugged design...hose sleeve protectors also offered against chaffing hoses....a must IMO. I own a Damond...very...very happy with purchase!
Rivy
That's a hell of a recommendation!
Rivy
Awesome, can't wait to hear.
Radium engineering also has a good kit for the PCV and crankcase side. I think you can get it from them or Mountune
The Damond also includes a check valve. [thumb]
