Engine oil in battery box
jodyr
Phoenix, AZ, USA
I had to replace my battery today (1 month out of warranty!) and I discovered dirty engine oil in the battery box. Everything is running fine and there doesn't seem to be a leak, so I'm going to blame a sloppy mechanic the last time I had it in for service, but wanted to mention it here in case others have seen the same.
Or is it Trans fluid venting from the transmission vent port? It sits right below the battery tray. Might be worth an inspection.
jodyr
jodyr
Phoenix, AZ, USA
That's more likely. I just had the transmission seals replaced about a month ago. On a cursory inspection, the oil looked like dirty engine oil, but it's not like I'd know the difference anyway. Thanks for the info.
