Seriously!? I was freaking the heck out. I was always told there should be little to absolutely 0 blow by. I also noticed that when I pulled the cap very very faint white steam was coming from the cap. Is that normal as well?
No, I was talking about the factory system. The air and vapor you are describing when opening the oil cap is managed by the system when the oil cap is sealed.
Have you ever checked an engine for blow by gasses? That's the most common way to do it and I can promise you it's done very often as a diagnostic technique. After doing this task a compression test would be preformed to confirm that blow by is present.
I strongly agree haha. Unfortunately I don't have a comp tester and I really can't imagine that it's messed up with 5k on it. Still runs like its a## is on fire.
This is also the first time I've ever owned a boosted vehicle. I still have to figure out what is normal and what is not. The knowledge you have provide me with is appreciated. Clearly you know your stuff being you have a nasty evo and have owned 2 FiST. thanks again.
