Euro projector headlights + bi led lens.
Ukraine, Kyiv Oblast, Ukraine
I bought a bi-led lens matrix type in China.
https://russian.alibaba.com/product...led-projector-lens-headlight-60769843509.html
Installation of lenses is very simple. The lens mount is the same as the OEM lens mount..
All elements are in the middle of the headlights.
There is nothing outside.
Before halogen and after bi led
At night on the road.
IMG_20191027_192644.jpg IMG_20191026_195040.jpg IMG_20191031_170559_1.jpg IMG_20191102_224306.jpg
fog
Circuit for connecting high and low beams of DRL
Charlotte, NC
Interested to see how this mounts inside the housing. I assume this is an all-in-one LED projector with integrated bulb, and you still had to take the headlights apart for install?
M
Yes, this is an all-in-one LED projector. The headlight is completely disassembled and new lenses are installed.
Ede, Gelderland, Netherlands
I know I’m very late to this thread but did you make any pictures of the mount inside the headlight? Can I just remove the OEM projector and install an NHK IV plus projector with the G5 mount standard?
Portland
If you just need photos of the inside of the headlight assembly itself, I have a broken one sitting in my garage and I'd be happy to take some photos for you, just let me know what you need.
Yes please that would help me out a lot. The projector and it’s mount are very important for me cause I’m trying to retrofit a projector and really need to know the bolt pattern and stuff so that I know what to buy, nobody online has any information about this except this thread.
so it would really help me out a lot 🙏
Portland
Cool - it's not technically MY garage, it's at my parents' place down the road, but I'll do my best to get those to you in the next few days.
XanRules
Portland
Here you go. I was not able to get any sort of measurements as I'd have to have fully opened up the light to do so, but this is what it looks like. Basically, the low beam projector is attached to the rest of the housing with four screws, and then routed into the leveling motors/screws somehow. It is absolutely conceivable to me that you could swap in correct projectors as indicated in the original post since the projector itself is a discrete unit.
Happy to take more if needed, these may not be as clear as intended.
IMG_8723.jpeg IMG_8722.jpeg IMG_8727.jpeg IMG_8726.jpeg IMG_8725.jpeg IMG_8724.jpeg
