HS Setup
Plainrt
Sheboygan
Good catch! I was looking at the the wrong long link to a set of team dynamic wheels. The RPF1s are definitely 43mm. I took advantage of Oako's New Years sale of buy 3 get 1. https://www.oakos.com/ENK-379-670-3443BP.htm
Awesome advice for the shocks. Not sure if I'll have enough cash saved up for next season to get all Konis on all four corners since I'm saving for tires currently. Seems like a good idea to gradually change things as well to see how the car responds. It's going to be a huge enough change going from OEM. tires to the RE71Rs.
When I had the MINI, the exhaust to get was a Milltek. They seem to make a great product, although I do not have personal experience.
It's really a bummer that HS won't allow for lowering springs, that would really seem so solve a lot of people's worries.
If go konis wait till spring time and they will go on sale.
Plainrt
Sheboygan
I need way more tire if i want to win smf imo.
225s would be nice. You could have fun in that class. I’d go for it. I’m just enjoying all the hate I get with my car so it’s hard to switch classes. I’d love to build car for sth class
Anchorage
Wish I could find more info on the B6 vs KONI yellows. B6 shocks are certainly cheaper but I can't really find anyone that runs them competitively in HS and you seem to be the only one I've found who has tried both. Mostly just people temporarily in HS while they move on to STH. I am interested in hearing more. I'm waiting to install everything until 1st week of March so I do have the opportunity to return and swap them.
The person I spoke to said he runs no rear bumps on the tops of the shocks which allows him to adjust them without dismounting them. Not sure how that works yet. As you mentioned about precision I do plan to try what another user has done and time the rebound of the pair of shocks after adjusting and ensure they are equal.
I should also note as the person I spoke to mentioned that his setup is the same the one Mike King uses who has won HS nationally twice.
I read this after working with Konis on both my WRX and my FiST, and it kind of reflected what I had experienced- while adjustability is nice, the repeatability of the Konis is kind of iffy- clicks on one shock don't necessarily equal clicks on another shock, and the amount of change is not steady across a single shocks range of adjustment. If you had access to a shock dyno, it would certainly make the settings more consistent.
That being said, I only had Konis on the rear of my Fiesta- the fronts weren't available at the time, so I went with Bilsteins, and set them originally to 3/4 stiff, but then dialed them back to a 1/4 turn from soft, and I still felt the rear was over-damped. I was then able to fit the B6s all around, and the car felt like it matched, front to rear (not surprising, seeing as it had a full set of B6s!), and rode much better on the street.
I wouldn't doubt that a properly tuned set of Konis would be better for autocross than out of the box B6s in a head to head comparison, BUT I also think that Bilstein has much better suspension experts on staff than me. I happen to have some rear Konis in the classifieds....
edit: added link
PunkST
Menasha
true. Right now name of the game is repair what last winter did, and get better suspension. These stock dampers and eibachs are pretty worn out šŸ˜‚
Portland, OR, USA
Oh man, I feel ripped off now that I paid full price for a set back in November. =(
My HS plan is based on last years HS winner. He had Koni Yellow front/rear. Fronts set ~ 5-8 clicks full soft, rears 1/4 click from full stiff, Catback (for sound, not performance), ligthest 16" wheel you can get... and thats it. He did not run a rear sway as, in his opinion, it would only exacterbate the issue of tri-pod/roll over risk. The car will want to roll from the rear, so a stiffer rear bar will just lift that inner tire even more. He said that the guy that the roll-over risk article was based on was a new driver on sticky tires (R888s?), the point being you just cant be coming out of a faster sweeper in one direction, and then yank on the wheel the other direction.
North New Jersey
Thread Starter #29
Correct me if I'm wrong but while the rear sway bar may pick up the inside tire earlier, it wouldn't increase body roll. If anything picking up that tire earlier would reduce rear grip and cause the back end to come around rather than cause the car to roll more.
Portland, OR, USA
A) I am just regurgitating information passed to me by the guy that won nationals last year, so I cant speak to personal experience.
B) I agree that it wont increase body roll, it would reduce it, and take away rear grip sooner. But... Theoretically the way I see the issue: at the point the inside wheel starts to lift (so ouside isnt slipping now, it found traction and is gripping) there is snap effect that could cause the car to roll over more suddenly, instead of giving more warning and leaning over or tripodding.
My practical knowledge. I race RC cars on high bite carpet. A rear sway is a great tuning aid, but when fighting traction rolling removing the RSB can help reduce that sudden snap traction roll problem.
Obviously many people here are running a RSB with success, but the guy that won nationals didnt run one, so I am not going to start off spending that money.
Albuquerque
#31
Hello all,
I have not weighed in on any of these discussion threads but I have read every one with great interest. From and competitor standpoint I do not consider myself knowledgeable or skilled enough to offer advice on this (or most other) topics, I believe in keeping my mouth shut and my ears open to learn…
With that said, I can only speak from my experience from running about two seasons regionally in HSteet class.
I run with several good drivers in our region (several are members here) and we have discussed multiple times on what equipment actually improves the car.
In my opinion the only real requirement is a decent lightweight wheel and the best tire for that season.
Koni yellows are a good thing to have and are not too expensive so this is almost a given if it is in your race budget.
I really feel the rear bar is a nice to have / driver dependent item. Some drivers may benefit from it others may not actually see improved times.
The rest is driver talent (or luck in my case) and possibly course dependency. (Part of the reason I like HS class so much, it does not seem to be heavily equipment oriented.)
I base by statements on the fact that I have mostly driven my car stock with 16x7 wheels and re71-R’s and a drop in filter.
My two main competitors have drop in filter, 16x7 wheels and re71-R’s, Koni yellows, Cat back and a rear sway bar.
We trade spots continuously during every event meaning our times are better by a few 10ths between runs. Sometimes I come out on top, other times they will come out faster depending on the day, but it is usually by .5 sec or less on a 40-50 second course. This has held true for 20 + events with 8-12 runs per event.
The first partial season I regularly got beat me by .5 secs or so, the next full season the only change I made was to swap in the Corksport adjustable struts from my Mazda2 about 3/4 of the way through the season.
Running the adjustable struts did seem to have some small improvement, but it may well have been me learning the car better. The results have remained nearly the same with either driver being ahead by a few 10ths.
With all that being said, my plan for this season is to:
1) Swap out the Corksports for Koni yellows (in the front)
2) Test out a rear bar this season. (undecided on which one)
My goal is to do well regionally, maybe go to a few National events and then attend Nationals and have my rear-end handed to me. 😊.
hot springs
#32
Tomorrow I’m going to order parts for my build.
Koni yellows
Front bar (not rear)
Rivals for locals and some yoks for national events n
I have talked to a couple of trophy winner at Nats from 2019. There is a little bit of a mix of thoughts so there could be more later.
Albuquerque
#33
Koni yellows
Interesting, I had been reading up on the front bar vs rear bar ideas..
One train of thought seems to be that reducing the rear grip with a larger bar increases oversteer which helps balance the car. (This is the model I have always heard)
The other train of thought seems to be that since MacPherson front suspensions gain camber under compression and this reduces the size of the front contact patch in a corner.
Therefore, a larger front bar would reduce the amount of roll, thus reducing the amount of camber gain and help maintain tire contact patch.
There also may be a trade-off of increased wheel spin due to the inside front tire traction loss.
It would be very interesting to see results of different set-ups.
hot springs
#34
I’ve had no problem with rotation in the car. I’m buying a sway bar set so I can do either.
Albuquerque
#35
Yes, that's a good idea... cover both bases at once just in case.
I was looking at the Front bar installation instructions from several manufactures. Unfortunately it appears they all recommend the dropping the front sub-frame for the replacement which will make it more difficult to ā€œundoā€ the front bar replacement once it is done.
This could make it logistically more difficult to test both bars in the same time-frame… as in back to back testing of some kind, (with timing involved) which would be ideal.
Easy enough to install and uninstall most of the Rear bars, that could be done at an event / test and tune, but the Front would be more problematic since it would require a complete swap from the test bar to the original bar or vice versa.
hot springs
#36
You have to be ####ing me. What kind of engineering madness is this.
Albuquerque
#39
I’ll YouTube it later but that sounds like a total time killer.
Yes, apparently, I failed to convey the humor in my suggestion regarding the ability to test a Front bar in some sort of back to back testing… not actually feasible in the real world.
It would be a very interesting data, but likely not even necessary. The same information may be had from Solo-storm or similar data review after swapping parts.
Portland, OR, USA
#40
This doesnt seem to hard. Install front SB, go and test, come in install rear sway bar, and remove end links on front sway bar, go test again...
