I tried to replace a strut, now the steering knuckle won't reach it
New Jersey
Like the title says, I took the old strut out and let the steering knuckle/brake assembly hang and did not think to restrain it while I was putting the new shock in. Now, the steering knuckle won't budge enough to go back into the new stut. It seems like the CV shaft is disengaged/pulled out, but when I turn the hub on that side, with the car in gear and both wheels raised in the front, it makes the other side turn also. Doesn't that mean that the splines and everything are engaged? I tried all amounts of pulling, pushing, wiggling, turning the hub back and forth and no luck. At this point, I'm ready to pull everything apart and remove the CV shaft to make sure its not pulled apart internally inside the boots. Any suggestions are greatly welcome.
Western NY
You need to jack the knuckle up. A small bottle jack is perfect for this type of job. Place it under the ball joint (control arm)_...I doubt you pulled the CV out....it just takes more force to lift the knuckle than you may think!!
The strut not only turns but moves in/out and back/forth on its mount. Sand off any corrosion/build-up on the old knuckle's contact surfaces and anti-sieze or grease the contact surfaces. You'll need to turn the strut a bit in the process of lining them up. Use the shaft of a long 3/8" socket extension to help pull the holes into perfect alignment for the two bolts. IIRC I also had to use a floor jack as Geebs mentioned.
Sam4
West Chester, PA, USA
"It seems like the CV shaft is disengaged/pulled out"
Thats exactly what has happened - not that its happened to me...twice :rolleyes:. The cv joint is distended, if it was a knee it would be Linday Vonn's - they're (relatively) cheap from Rock Auto. I must not have supported the shaft and let it droop while doing struts...
T
New Jersey
Already tried that.
T
New Jersey
Thats not the problem I'm having. I can't even get the strut to touch or go near the knuckle right now.
T
New Jersey
Sounds right. How did you fix it?
Western NY
Sorry about this Timmmo57, I think I understand....so it's not simply that you can't get the knuckle up high enough, it's that you can't get it IN far enough? I've seen videos where people repair the CV....but to do it they always remove it from the car, in which case I would just buy a new one. Trying to get it to line up perfectly while still on the car is not easy, and if the bearings inside have moved, it will damn well be impossible.
If you think this has happened, your going to need to remove the knuckle anyway so when you do it's worth a shot to see if you can re-engage the CV by hand.
T
New Jersey
I think you are on point. I took the boot off of the end of the shaft where it goes into the trans, and it fell apart. I have to get it back together at least for now as it's at my work and it CANNOT be here come tomorrow morning (its inside one of the buildings). But for the life of me, I cannot get the ball joint to seperate, nor can I get the axsle to pop out of the knuckle, so its not easy at all.
Western NY
If you got the nut and bolt out of the ball joint but it won't separate, carefully jack up the KNUCKLE (not the control arm) and rap the ball joint area with a mallet or hammer. You can hit it pretty hard, hit the the bottom under the ball joint. If you want to rap on the side of the control arm, use a block of wood or something so you don't bend up any metal. If/when you get it off, you should be able to pull the knuckle off the axle. Obviously, you already removed the spline nut...
GA
Hopefully you can get that axle out and fixed or install a new one. Sounds like a nightmare with a deadline hanging over your head like that.
T
New Jersey
Thread Starter #12
Yes. Yes it is no fun. However, I did get it "fixed", for now. I was able to get everything apart except I still could not get the axle out of the steering knuckle/hub. I banged on it with a hammer but it doesn't want to budge. Anyway, I ripped the boots on the ball joint and tie rod, so I am replacing those along with the axle that had the bearing come apart in the part nearest the transmission. It was NOT pulled out of the trans, and the little ring on the end of the axle was still in its proper position. What was otherwise an easy job, turned into a very time consuming, expensive, and aggravating ordeal. Next time, don't let the steering knuckle flop oved if there is not strut connected to it.
Capri to ST
CHAPEL HILL, NC, USA
This reminds me of The Andy Griffith Show episode where Andy's out of town and Goober the mechanic is supposed to be a temporary deputy. He reassembles a car inside the courthouse which is still in there when Andy comes back, much to his dismay.
https://www.google.com/search?rlz=1...ve&ip=1&vld=cid:58146f72,vid:E7XT3lBm6GA,st:0
I hope you fare better than Goober did. Andy got his gun out and told Goober to get the car out of the courthouse. Good luck.
https://www.google.com/search?q=andy+griffith+episode+where+goober+fixes+a+car+inside+the+courthouse&rlz=1CBKPLI_enUS1137&sca_esv=29ccdfb8ba38376c&sxsrf=ANbL-n7ICIuh0L2OKQh1ne1iFv1z8rk3Hw:1776630512130&source=hp&ei=8DrlacL5Bdfc5NoP_saIiAo&iflsig=AFdpzrgAAAAAaeVJAGcoHmRETnC8zLmBmR0F1f7bEJeF&udm=7&oq=a&gs_lp=Egdnd3Mtd2l6IgFhKgIIADIHECMY8AUYJzIEECMYJzIEECMYJzIREC4YgAQYsQMYgwEYxwEY0QMyCxAAGIAEGLEDGIMBMg4QLhiABBixAxjHARjRAzIOEC4YgAQYsQMYxwEY0QMyDhAuGIAEGLEDGMcBGNEDMgsQLhiABBjHARjRAzILEC4YgAQYxwEY0QNIgRhQAFgAcAB4AJABAJgBNKABNKoBATG4AQHIAQD4AQGYAgGgAkGYAwCSBwExoAe0ErIHATG4B0HCBwMzLTHIBwmACAE&sclient=gws-wiz#fpstate=ive&vld=cid:beca8eee,vid:eFLlC5r8BzM,st:0
GA
I removed my struts to install new springs, but I can't remember if I did anything to support the axle and hub. I'll be mindful of this next time I pull the struts off.
T
New Jersey
Thread Starter #15
Is the axle press fit into the hub on the knuckle? Is there a magic trick to get it to come out? I'm banging on the end of the axle with a mallet but it won't budge Need to get this figured out to get the new axerl in when it arrives....
Suwanee
it might benefit from a puller. actually, it's a pusher. Called a hub press IIRC. i rent one from autozone when i have to do this job. you can also try a punch in the center of the axle and hammer away, but if you're having this much trouble, this is probably going to just break the punch. get the puller.
