I tried to replace a strut, now the steering knuckle won't reach it
New Jersey
Like the title says, I took the old strut out and let the steering knuckle/brake assembly hang and did not think to restrain it while I was putting the new shock in. Now, the steering knuckle won't budge enough to go back into the new stut. It seems like the CV shaft is disengaged/pulled out, but when I turn the hub on that side, with the car in gear and both wheels raised in the front, it makes the other side turn also. Doesn't that mean that the splines and everything are engaged? I tried all amounts of pulling, pushing, wiggling, turning the hub back and forth and no luck. At this point, I'm ready to pull everything apart and remove the CV shaft to make sure its not pulled apart internally inside the boots. Any suggestions are greatly welcome.
Western NY
You need to jack the knuckle up. A small bottle jack is perfect for this type of job. Place it under the ball joint (control arm)_...I doubt you pulled the CV out....it just takes more force to lift the knuckle than you may think!!
The strut not only turns but moves in/out and back/forth on its mount. Sand off any corrosion/build-up on the old knuckle's contact surfaces and anti-sieze or grease the contact surfaces. You'll need to turn the strut a bit in the process of lining them up. Use the shaft of a long 3/8" socket extension to help pull the holes into perfect alignment for the two bolts. IIRC I also had to use a floor jack as Geebs mentioned.
Sam4
West Chester, PA, USA
"It seems like the CV shaft is disengaged/pulled out"
Thats exactly what has happened - not that its happened to me...twice :rolleyes:. The cv joint is distended, if it was a knee it would be Linday Vonn's - they're (relatively) cheap from Rock Auto. I must not have supported the shaft and let it droop while doing struts...
