Just Received a GFB DV+ - and it looks different (and quite ragged)
New York, NY
Hi all,
I just received a GFB DV+. It was apparently drop shipped directly from GFB's distribution center (ordered through Whoosh). It looks different from others I've seen, and lacks the red/orange rubber piece at the end of the brass looking piston, and instead has a blue o-ring. The surface of the piston also appears to have a heat stained fingerprint. And some of the other components just look ragged and poorly finished. The black machined body/housing looks good and is well finished.
Is this normal and consistent with what yours looked like?
Thanks.
rotation_nation
New York, NY
I wonder if it is a counterfeit/knock off??
That was my immediate reaction when I took it out of the box. I emailed Ron at Whoosh, but he said it was shipped directly from GFB and therefore zero chance of being a counterfeit.
I will reach out to GFB and let everyone know what they say. I don’t want to install it though - I feel like tolerances and machining finish are quite important for a part like this.
Kansas
Can you post a pic of the logo and patent number on the valve? The font/size can point to counterfeit. Also the foam seems off. It’s usually more dense looking.
Other odd item as you mentioned is the blue o-ring. Even the counterfeits have the red rubber seal. Strange.
rotation_nation
New York, NY
Yup - see below.
Kansas
Some more odd things I notice:
1. On the patent print side, it should have the model number “T9358” on it.
2. On the under side, where that engraved “S” is, it should actually be an “8”.
