led turn signal help
I put in some red led turn signal lights and now have hyper flash which I was aware I was going to have. I also have load resistors to help with that. The question I have is in the front turn signal I use the blue/green blinker wire and the black/yellow ground and nothing helps. There is 2 black/yellow ground wires and also a green/red for parking lights. Do I run blue/green and green/red together and then both black/yellow. Any help on this would be greatly appreciated.
MKVIIST
Load resistors mount from positive (hot) to negative to create an artificial load.
In this case Blue/Green to Black/Yellow. Once they are connected they can get really hot so make sure you mount them clear of any wires or you'll risk melting any wires it comes in contact with.
