I sent an email to Mike Robins (Supervisor-Info Center) at Ford Racing regarding your interpreted take on the Ford Performance Limited Warranty. See below...
Looks like the info the Ford dealers told you is incorrect. I would like to apologize if I was a bit harsh with you, again I'm sorry for that.
"Marc,
I hope all is well with you. From what I?ve read, and unless I missed anything?.you?re reading the statement the correct way. We write these things with what I believe, leaves no room for interpretation. Mike or myself would also be happy to chat over the phone if any of this is confusing.
I?ve answered here in red:
Questions:
1.If the MP215 kit (in theory) were to cause an engine failure during the base 3year 60,000km
(miles) warranty would Ford cover the repair under the new vehicle warranty?
?YES is the short answer. If it is attributed to the calibration, we (Ford Performance) cover it, if it is attributed to a base/mainstream vehicle failure-Ford covers it. This may be confusing to a consumer, but the take away is that either way-it?s covered.
2.Who is responsible for fixing an issue caused by warranty approved mountune part (MP215, Intercooler, short shift kit, etc), Ford or Mountune?
I believe I answered that above, but the answer is Ford Performance.
3.I have the Ford extended warranty on my Fiesta ST, does the extended warranty cover a MP215 caused failure?
The black and white answer is NO. However, you have to also remember that just because your vehicle has an aftermarket calibration, that does not automatically void any warranty, extended warranty or not. The failure HAS to be PROVEN to be caused by the calibration. For example-if your strut fails, is this a result of the calibration? No, therefore ESP would cover it.
Would like to clarify this on the forum as I don?t like having false information for other potential users that may steer them clear of Ford Racing parts or mountune parts.
If you could take a bit of time to comment on this would be most appreciated.
Not to shoot down a poor example, but an intake is not a fair example. These are controlled by MAP sensors and have no effect on calibration. That?s why you can run a different intake on these cars, as well as Focus, and not have issue. Calibrated or not.
Thanks,
Best regards,
Mike Robins
Ford Performance
(800) FORD-788
www.fordperformance.com
www.fordperformanceracingparts.com
www.fordshowparts.com
Sent: Monday, June 20, 2016 3:45 PM
To: Robins, Michael (M.)
Cc: Goodwin, Michael (M.J.)
Subject: RE: mountune Intercooler Installed - 2014 Ford Fiesta ST - Warranty Registration
Hi Mike,
I?m a member on one of the Fiesta ST forums and have being going back and forth with one guy regarding the limited warranty to the performance packs. Or in my case the mountune MP215 kit.
I have read the warranty document and it all seems very straight forward to me. However a member of the forum is basically trying to say if the MP215 kit during the base 3year 60,000km warranty were to cause the engine to fail and they said it was caused by the MP215 kit then the warranty would not cover the repairs. This seems to go against everything the warranty document talks about.
https://performanceparts.ford.com/warranty/include/pdf/Select_Parts_Warranty_Statement_2015.pdf
Somehow he understands the following sentence to mean you have no warranty with mountune warranty approved parts:
?Engine, driveline and suspension concerns not caused by the use of Ford Performance or mountune parts remain eligible for warranty coverage according to the terms of the New Vehicle Limited Warranty.?
I read the above sentence as anything not caused by F.P. or mountune parts are still covered by the base vehicle warranty. Based on his interpretation he?s trying to say this mountune MP215 tune is no more warranty friend then compared to a Cobb tune. He was also trying to say that if something goes wrong with a mountune part and it causes damage that somehow you have to deal through mountune fix the issue, which seems crazy. Not too sure if he?s trying to get you guys to agree to what he?s saying?? See below what he?s saying.
?I am quite certain now that I am right. I called and spoke with two dealers. I will be visiting a third tomorrow (getting some warranty work done at this one), and will confirm with them as well. They confirm my suspicion that no aftermarket item voids your warranty (not Cobb, not Mountune, etc). Mountune is no more "warranty friendly" than Cobb. The thing that is different amount Mountune is that they will replace that item, if it is found defective, under their warranty for the remainder of your factory 3 year/36k. That's it. Mountune gives you a limited warranty on the product itself.
They also said: If an aftermarket item on your vehicle that did NOT come installed from the factory (even if it's Ford Racing or Mountune products) -- if these items are found to have caused a problem, then your factory warranty will not cover the damages. I re-emphasize, if your Ford Racing or Mountune products are found to have caused a problem, the damages will not be covered under your factory warranty. Instead, you need to look to Mountune to help resolve your issues (most likely, they would just replace your product... I doubt they would replace your engine or any severe warranty work if that were the case).
Here's the example they gave me: Let's say your Mountune intake causes a code related to O2 levels or some other sensors failing (or insert something perhaps more appropriate/realistic, just using intake as an arbitrary example), then Ford will not replace your intake or anything else that your intake has damaged due to normal use. The "warranty friendly" means that Mountune is responsible for replacing your intake and paying for whatever other damages have occurred for the remainder of your factory 3 year 36k. Not sure about you, but this isn't a situation I want to be in, because I've called Mountune and they gave me no comment. They told me to refer to Ford. Maybe they would replace the intake (because they would have to if it was a faulty product) but I am genuinely uncertain whether or not they will cover the bill from the rest of the hypothetical damage.
Hope this all makes sense. If someone knows better, and can cite something concrete (like, an email from someone high up on Ford Racing would help...) or a statement from someone at Mountune. Please do. I've been looking for answers and gather this much, but it hasn't exactly been transparent.?
Questions:
1.If the MP215 kit (in theory) were to cause an engine failure during the base 3year 60,000km warranty would Ford cover the repair under the new vehicle warranty?
3.I have the Ford extended warranty on my Fiesta ST, does the extended warranty cover a MP215 caused failure?"
