New Alloy intake manifold from PumaSpeed
none
I know the name has stigma, but it doesn't discount the fact, products for our platform still flows from ye olde country.
https://pumaspeed.co.uk/product-Pumaspeed-Racing-Alloy-Inlet-Manifold-Fiesta-ST180_21910.jsp
Pumaspeed desription:
Pumaspeed Racing Alloy Inlet Manifold Fiesta ST180 - Pumaspeed Inlet Manifolds
  • Hassle-Free direct bolt-on replacement for OEM manifold.
  • Variable volume spacers allow precise power band tuning.
  • Durable cast alloy construction handles high boost without cracking
  • Optimized internal geometry maximizes airflow and throttle response
  • Premium black textured finish enhances engine bay aesthetics
Pumaspeed Racing Fiesta ST180 Alloy Adjustable Volume Inlet Manifold
Unlock the true potential of your engine's breathing capabilities with the Pumaspeed Cast Alloy Tune-able Inlet Manifold.
Limited Production Run arrives 2nd Week of December
Engineered to address the known weaknesses of standard plastic OEM manifolds—which are prone to cracking under High Boost pressures and heat cycling—this upgrade offers unparalleled durability and reliability for high-performance applications.
What sets this manifold apart is its innovative variable volume plenum design. By utilizing interchangeable spacers, you gain the unique ability to fine-tune the intake runner volume.This allows you to shift your engine’s torque curve to match your specific needs, prioritizing low-end grunt for the street or top-end horsepower for the track.
Designed as a true direct-fit solution, this robust alloy manifold installs using existing factory mounting points and sensor locations, ensuring a straightforward upgrade that delivers tangible performance gains and a premium aesthetic under the hood.
Key Features & Benefits
* Robust Cast Alloy Construction: Far superior to OEM plastic, providing maximum durability and resistance to failure under high boost and extreme engine bay temperatures.
* Variable Volume Technology: Includes modular spacers that allow for the customization of plenum volume, enabling precise tuning of the power band and torque characteristics.
* True Direct Fitment: Engineered as a hassle-free, bolt-on replacement that integrates seamlessly with stock throttle bodies, fuel rails, and sensors without requiring custom fabrication.
* Optimized Internal Flow: CAD-designed runner geometry ensures smooth, high-velocity airflow to the cylinders, improving throttle response and overall engine efficiency.
* Premium Aesthetic: The sleek, black textured cast finish significantly enhances the visual appeal of your engine bay, signalling a serious performance machine
Now discuss!
daloonie
none
The plastic ones are quite stout, true. I would wonder, what measure of boost it would need to crack one. And think, the bottom end and fragile cylinders would crack and bend before even needing an alloy intake.
What is interesting though is the variable size spacers they can supply, with play with intake runner lengths. Those might prove the most useful out of this whole ordeal.
