P2282 is an OBD-II generic code for the engine control module (ECM) monitoring the vacuum in the intake manifold at idle. This code is triggered if excessive air is getting into the intake unmetered which indicates a vacuum leak.
Do you have a boost reference adapter for the turbosmart bov/plumb back or do you have a throttle body spacer or intake manifold spacer?
