S280 Turbo on New Long Block - Unable to Build Boost via Tune for Six Months
Grsemky
Arizona
New TIP and MAP sensors installed today. No change. We have confirmed the harness is good, and can see the pulsed ground coming from the ECU at the BCS harness. Contacted Cobb to see if maybe there was any chance the Acessport was bad. I'm going to have a third BCS put it in because there's always the possibility the new one we bought at JST was bad.
I have another hypothesis. I get the "Hill Start Not Available" Message from time to time suggesting an ABS sensor might be bad. I'm pretty sure these sensors feed the traction control system data. Is there any possibility that is impacting torque tables in the ECU?
That's an easy feature to turn off in the sync menu, might be worth a try to turn off that feature and an even long press esc to remove stability control for the test 🤷🏼‍♂️
DrivenMind
Atlanta, GA, USA
Thread Starter #22
I'll try it tomorrow. I may attempt to unmarry the AP from the car, and reupload the config afterwards. This is absurd, and I'm about ready to sell the car.
sczamun
U.S. Air Force Veteran
Indianapolis
This is the path I would go next and I would verify the ABS sensors are doing what they are supposed to be doing with an oscilloscope. I would probably do a quick check to see that the AP displays the correct gear that you're currently in.
I would hold off on replacing the BCS or at least test it manually.
DrivenMind
Atlanta, GA, USA
Thread Starter #25
We found it this afternoon. Though I'm not sure I understand what the solution is going to be yet, or why it worked on the stock set up, but not the new one. I had been wondering if the BCS was seeing differential pressure, and mentioned it to the installing shop owner when I dropped it off. Per the instructions with the BCS it looks like it was routed correctly. Today my mechanic got under the car and drew a map of the pressure of everything in the lines. The turbo outlet was at 15 psi on one side of the BCS and the BCS intake return was routed to the block that the Turbosmart Kompact shortie bov is mounted to (the same one the factory diverter valve mounts to) because it was also seeing 15psi. As soon as it was removed the pressure differential was restored, and the BCS started controlling boost. With that being said, I'm now wondering where the intake return line is supposed to go, and if this bov is actually compatible with this set up. I don't think the S280 came with any charge pipes with nipples to attach to, but I presume the intake return needs to go back to the intake side before it enters the turbo. Could someone share a picture of how theirs is routed so I can compare. I also assume I need to put a plug or vacuum cap on the nipple if its not in use?
DrivenMind
Atlanta, GA, USA
Thread Starter #27
I think I see whats going on here. Is it just me, or is my diverter valve mounting block in the plumbing in the opposite orientation to this set up? I think they installed it backwards. The valve in the bov is pointing towards the compressor and not the pressurized air coming out of the turbo.
DrivenMind
Atlanta, GA, USA
Thread Starter #29
That has to be the problem then. My mechanic was telling me to run the intake return to the bov to atmosphere, but I noticed I still didn't have any bov on the test drive so I was racking my brain trying to figure out what in the world could be different about the set up. That's the problem. I can't believe we all missed it this long.
DrivenMind
Atlanta, GA, USA
Thread Starter #31
That was it. After looking at that picture and realizing what I was looking at, I had a friend give me ride over to the shop and grabbed the car. I got under it an hour ago with some hand tools and pulled the bov adapter and oriented it correctly, and reconnected the intake return from the BCS to the block the bov sits on. That was of course the issue with the bov not working too. Its properly quick. On the base map its spinning 3rd gear up to 85mph at like 28psi. (Granted its cold) But I'll be pretending the fireworks are for me tonight. Thank you guys for your help, I can't believe it took that long to figure it out.
DrivenMind
Atlanta, GA, USA
Thread Starter #37
did you get a pic of how it is supposed to be setup?
The post is above. The bov is there to vent pressurized air and return some of it to the compressor to keep the turbo spooled. It can't do that if the blow off valve isn't facing the pressurized side of the pipes. The way it was oriented the turbo was effective pressurizing the the ported block with the intake return line meaning the boost control solenoid was not seeing differential pressure, and had nothing to reference to control boost.
Thank you guys for your help, and taking the time to read all this goofy drama. I sent my first set of datalogs to the tuner today. Car is a monster in 3rd and 4th gear, and a limited slip differential needs to be next.
Atlanta
#38
Would love to get a ride at some point to see how different from stock the midrange is. Can't decide about doing the S280 with injectors, etc. or leave it as is.
