- Member ID
- #1040
- Messages
- 669
- Likes
- 345
I have purchased the Wilwood Brake Kit from 2J Racing and I am experiencing a problem and would like to pose a question to those who have purchased the kit. If you have not purchased the kit then please do not respond.
Also regardless of the question this is not a matter of whether I should or should not have done anything differently so lets please stay on topic, This pertains to what I was recommended to buy and what I was sold.
I would like to ask the group, who has purchased this kit using the cross-drilled slotted rotors with the BP-20 brake pads? What application are you using the vehicle and how much are you driving the vehicle daily, and are you experiencing any vibrations.
In addition what I need you to take into consideration is that I drive about 6000 miles per month on this car. No that is not a misprint, and not an exaggeration and can produce a photo of the odometer if required. It is possible you will not have discovered the issue yet, as you are not putting the miles on it that I am. Being in the car this much I am intimate with the car and how it feels and drives.
While I need to get to the bottom of this, It is 100% not my intention to cause harm to 2J Racing. It is also important to understand that the Kit sold by 2J racing is not a kit offered by Wilwood. 2J Racing has built this kit using Wilwood parts and selling 19 kits does not make them experts on the subject matter. Wilwood clearly marks their products for OFF ROAD ONLY. They do not make a street drivable brake kit for any car. With that being said, this is not the first time I have used Wilwood products and consider their products to be top notch.
Keep in mind that I drive more in 2 months than 99% of the people on this forum drive in a year on this car. So everything I do in the car is exaggerated time wise. I will wear through many parts way before most of you do and this needs to be taken into consideration when discussing this problem.
What is going on is when the brakes were installed, we had road conditions which did not permit me to really try out the brakes. I was able to bed the pads according to the instructions, but there was no aggressive driving. This is 100% strictly a street car. It will never see the track in any way shape or form. Yesterday and today was really the first time I could get some speed out of the car, what I am experiencing is a severe shutter in the steering wheel on medium pressure to full pressure braking from 25mph up through 80mph. If I feather it, I don't feel anything and the brakes feel fine other than the typical noise and feedback you get with drilled and slotted rotors. It feels like a warped rotor problem.
Rotors were exactly in the middle of the caliper and not by sight, but my measuring them when they were installed and turned freely in the caliper with pads installed. The installation was as described with no issues or problems.
After having conversation with Wilwood, tomorrow 3/5/2015 we will be pulling the rotors to measure run-out and measure the wear on the pads. While this is not common on a new set of rotors, I have purchased a brand new set from wildwood for another application that was a wildwood kit, and the rotor brand new in the box had run-out by 8 thousands of a inch. And while you would not think you could feel that, you would be mistaken. And here is the big caution, Wilwood has clearly indicated that street driving on the cross-drilled slotted rotors with the BP-20 pad can damage the rotors. Wilwood reconfirmed today that it would not be unheard of to get a brand new rotor that had run-out. I am certain when I told Joe that today he thought I was crazy, Brock as well. That I was just some dumb stupid customer that didn't know what they were talking about.
When I advised Wilwood that I had the Cross-drilled slotted rotors and the BP-20 pads and was driving on the street, I was asked "who talked me into that?" he followed up with those are 150mph pads, and not meant for daily street applications under any situation.
Joe at 2j Racing is convinced that there is not a problem, and he may be right, but regardless of how many race cars he has built, and how many kits he has built for other cars, he has sold 19 for the Fiesta according to him and that no one has reported any problems, and if this is the case, that is great news, and I may just be the unfortunate one. Every car you build a brake kit for is different. Different because of the ABS system, in this car, different because of the Torque Vectoring, and pad selection is important due to application, and who knows what else. While I hold the upmost respect for Joe and his team, for which they have been extremely helpful in listening to my concerns, they were unable to offer any assistance and future purchasers should be aware that should you purchase this kit you are own your own and all they are able to do is sell you more parts at full cost. Joe feels it is not his fault and I do not blame him for taking that position at this time. Joe did select the pads for my setup and he was aware of my application.
If you are racing the car, it is possible that under extreme conditions and extreme braking you could experience some type of pulsing feedback in the steering wheel and that would be the ABS system. Under extreme braking it pulsates the brakes at 16 times per second. This is not an ABS issue. This is a rotor out of round problem, the question is what caused it. Under normal braking these should feel very solid from the moment you press the pedal to the moment you stop. If they do not feel like that you having something going on.
While it is possible I did something wrong in the installation, I do not believe this is installation malfunction. I believe the kit created by 2J Racing is first rate. I do believe this is a brake pad/ rotor problem.
There is no need to defend 2J Racing, That is not what this is about, 2J racing, Joe and his team are a very respected member of the community, make and sell great products. Based on my conversation with Joe and Brock, I truly believe Joe feels based on his experience this could not be a rotor or pad problem. He races his car all the time. I don't. But I can tell you, I drive more in a year than he ever sees on a racetrack.
If you have these brakes please share and answer the above questions for me to help me narrow this down for future buyers of these braking systems and maybe by chance help me come to a solution. If these brakes are not on your car, please do not offer any suggestions, you would be speculating, and that would not be helpful.
