D3 SS 3D I absolutely love the setup. The install wasn't very hard, just have to pull the headlights and hook up a few wires, then find a spot to mount the balysts and you're done. Fog lights are even easier. The instructions say to remove the wheel but I just turned it to full lock and I had all the access I needed. Only think I wasn't crazy about was the fog light aiming. I ended up putting a few spacers on the bottom mounting tabs to get them aimed up a bit. Other than that I have loved it.
I will say that I would be very mindful when putting the actual headlight bulbs in. My drivers side fit perfect but the passenger side was actually touching the little silver cone reflector thing inside the headlight. I just took the bulb out and moved the reflector a little forward with a flat head. Probably not even a mm of movement but it was enough to clear the bulb. Didn't change the beam pattern at all
Thanks, glad to hear you like the lights / setup. Iāve watched install videos for both the fogs and headlights so I have a general idea of what to expect. The install video on the fog did not include removing the wheel, they jacked up the front and turned the wheel inward, appeared to have plenty of access (sounds like what you did). On the other hand, I didnāt think about the headlight bulb potentially not fitting well into the OEM housing, but Iāll be on the lookout for any issues (thanks for the tips). Iāve gone ahead and bought some double sided tape, I will probably mount the ballast similar to how the video mounts them (inner fenders basically). Iām really looking forward to getting these on, currently on back order @ TRS, hopefully Iāll get them this month.
P.S. TRS has discount codes if you ask them via chat, used TRSFB10 for 10% off.
