XR650R
Eerie
Nope ESC full off I found it weird the back ones wore like that but I was hard on the brakes on track as was needed ;)
From what I've read, the brakes are still engaged. Or am I wrong?
Maybe some race pads on the back, too?
rodmoe
wausau
Torque Vectoring can not be turned off Correct :)
Next time will have Real track pads for sure swapping them out is rather easy once you get the hang of it and the right tools to wind the calipers back in on the rear and a thin 15mm open end to fit the caliper slider holding nuts while you loosen the 13mm end bolts.. Live and learn ;)
U.S. Navy Veteran
SFV, So.Cal.
This morning on my way to work, I broke my alignment.
Dave
U.S. Navy Veteran
SFV, So.Cal.
The two big bolts on the front struts were not torqued enough.
It is not fun when the alignment changes at the apex of a fast turn.
Dave
Sourskittle
Lakeland
Dave
I had a lower control arm come apart once in my srt4 in a corner. Yea... Not fun. Hope you didn't incur any damage...
U.S. Navy Veteran
SFV, So.Cal.
No, nothing damaged.
Just drove back down to Eibach too make sure.
Dave
Carson City
I tack weld parts that can slip out of position but carefully do I can just cut and move if I want to test a different setup.
After a couple of track days on DOT race tires I found this to be the best cure for barely any cost or time.
Sourskittle
Lakeland
I tack weld stuff all the time at work. "Non-metal worker" co-workers complain. I'm like, "really... It will never move, ever, and if you need it replaced or moved, its like 5 seconds with a torch".
Of course.... I work on heavy machinery, not painted cars, so... Lol. I had never though about tacking something like suspension parts, lol.
Carson City
Of course it works with steel to steel, etc...but I have had an incredibly good welder tell me he had welded aluminum to steel in a few applications to solve a problem.
rodmoe
wausau
Glad you only needed to swap out your depends there Dave ;) I hate it when it goes not where I point it too :)
U.S. Navy Veteran
SFV, So.Cal.
Fortunately I use Attends Breathable with tear tabs.
Dave
