iso100
This thing makes all kinds of noise all the time. Even part throttle. I'm going to coat the hot side of the shield in gold thermal tape.
I am very close to driving it, finally!
As soon as the front caliper mounts are done at the machine shop and shipped to me and the rear mounts done it will be on the road putting around breaking in the engine then I will run it for some data logging to send off to get the tune done....close, 5 months on the lift and soon on the ground and road!
JPGC
What did you do to your Fiesta ST today?
With all the work you have done, I'm definitely excited to see your results when you start testing it out.....so, what did I do today! I FINALLY GOT MY REPLACEMENT O2 SENSOR FROM FORD AND INSTALLED IT, lol. Apparently the upstream sensor is made in Germany. Car feels great and getting used to the new mods as well as data logging.
Just finished installing a Big Brake Kit.
323mm rotors.
Dave
MOFiST
Did you happen to see if it looked the same as that Bosch posted over in the order thread? Also curious how much Ford hit you for the genuine part?
JPGC
The part was $79.39. I also tried the 2014 Focus ST part and it was much shorter. The Bosch did look very similar, but I didn't try it out.
MOFiST
For that price I'd have waited as well. Not worth worrying about trying an unknown part. Happy it all worked out for ya.
JPGC
It's funny too because the upstream for both the Focus ST and the Fusion 1.6t are twice as much. They are both manufactured in the US and the Fiesta ST upstream was manufactured in Germany...this is going off of the parts pulled at the dealer when I was trying to find an alternate. They had the country of origin listed on the sensor itself.
Installed my WC Lathe Works knob and loaded my Freektune base map.
Which knob/options is that and how is the weight?
It is the titanium sphere, brushed, 4 small grooves on bottom half. A little heavier than stock. Had a super heavy JBR and a too light Cobb. For me the weight is just right. The sphere is a tad smaller than the Cobb and feels good for my smallish hand as did the Cobb.
dyn085
Awesome, thanks! Also, I think you'll really like the tune. I'll be sending off my datalogs from my first revision tonight.
LT Berzerker
Ordered some grit guards, buckets, UPGP, and weather tech mats for front & back :)
iso100
Loaded it up with two huge boxes of stuff to get installed tonight. Left box is MBRP 409 Exhaust and right box is a Curt trailer hitch.
I'm amazed it fit.
Installed some TD Imola 17x7.5 et45 on 215/40/17. Mountune Springs going on this weekend.
uploadfromtaptalk1409318227222.jpg uploadfromtaptalk1409318251332.jpg uploadfromtaptalk1409318275953.jpg uploadfromtaptalk1409318289579.jpg uploadfromtaptalk1409318301723.jpg
Installed my Steeda shift knob from my old Focus. To my surprise, reverse lock out still works with it. It looks taller but it really isn't.
