I could do the install in15 minutes...easy. The part is really well made, anodizing is great. All in all the FSWERKS stuff I have is top notch and I will buy more.
Just swapped the dome, glove box, cargo, and license plate lights all to LEDs, it looks so much better.
Installed the GFB DV (what a PAIN!!), the cp-e RMM (also a pain, and I HOPE it does actually 'break-in' some, since I don't mind the vibrations, but it makes a loud buzzing type noise almost like a heat shield rattling at idle rpms), and did the first oil change @ 1200 miles with an FL-400S filter, and Castrol Edge EP 5W-20 (gold bottle). [:)]
shouldbeasy
WHERE IS YOUR BUILD THREAD!!!!
Dude. You're all over this forum - just give in and start your own thread! I want to see you the progression of your car and a complete summary of the mods you've done!
Did a thing this weekend. Actually won something.
Sent from the Canyon's Edge
brbauer2
Swapped the antenna with the one from my mom's CR-V while she was over. She'll never notice.
Sent from my ONEPLUS A3000 using Tapatalk
Noodles,
Is that a zunsport front grill?
How did you get it to fit? is that a euro bumper?
thanks,
bgrazman
Yeah its the ZunSport grill. I made a post about it awhile back when I got it through a sponsorship. It takes a bit of wiggling and a couple zip ties to get it to stay in there. Its not 100% but it looks pretty good.
Thanks Noodles, I'll look it up...
I only managed to add valve cover breather...
Installed a center brake light flasher. Hope to not be rear ended!
https://vimeo.com/185175787
Only cost $8 on Amazon. Installed in about 30 minutes with plenty of breaks!
Sent from my VS985 4G using Tapatalk
Aaaand I didn't read the most recent page saw the link already thanks!
Can you post a link to this? And is it plug and play? I've been looking into something like this for a while now.
Qiorange Flash Strobe Controller Flasher Module for LED Brake Tail Stop Light 12-16V https://www.amazon.com/dp/B015QQ6YUC/ref=cm_sw_r_cp_apa_KojuybHVRCQ82
Hope the link works. It is not plug and play, but soldered in easily with an extra set of hands!
installed the wheel center caps I got on eBay, shipped all the way from Bulgaria
It's hard to make those out in the pic, are they engraved with anything/any logo, or just blank?? (I'm guessing you hated the TD center caps?)
Are those 1.2s 7.5" or 8" wide??
The more I see of the bronze 17s, the more I am sorry I did not get/order those instead of the gloss black.
they just blank black plastic, vaguely textured. wasn't a fan of the team dynamics caps at all, they're way too big.
those are the 7.5" with 215/40 tires
THANKS!
I hope those same exact tires, which I plan to use, are not too 'stretched' (for street use) on the 17x8 1.2s I am getting, since that setup already looks to be 'square', as far as wheel to tread width goes, despite that tire being 8" wide at the tread. ;)
