FORScan reverse/backup camera discussion thread
#86
[MENTION=2253]CanadianGuy[/MENTION] you have the actual proper pins? I may get you to send me some too, I can't even get them at work since the pigtail is considered "non replaceable" (we can get pins for lots of our harnesses but these ones are incredibly small and unique)
Sent from my SM-G930W8 using Tapatalk
CanadianGuy
#87
Yes I have the actual correct one. Which includes an alignment tab to prevent rotation. PM me your address and I can drop some in the mail.
CanadianGuy
#89
For those that have PM'ed for the connector will try to get come built this weekend and pop them in the mail next week.
#90
Success!!!! This took waaay longer than I wanted it to. The hardest part is running the wire in the hatchback. Second hardest part is remembering that the small white bulb is the reverse (white wire). Ended up wiring it to the brakes! Thanks CanadianGuy and everyone else on this post that figured out everything!
[/IMG]
brbauer2
#91
Congrats!
I've asked a couple times but since not many have done this not many have answered. Does your Brightness slider and Auto Day/Night toggle work with the camera enabled?
Any issues with the auto day/night switching and brightness adjustment for the display through the settings? I lost both functions (still showing in settings, just didn't work) when I changed the value in FORScan.
#92
I'll check and let you know.
Congrats!
CanadianGuy
#93
[/IMG]
Congrats.
CanadianGuy
#94
Congrats!
I checked mine and indeed the auto brightness detect no longer works and is set to max. I reconfigured it to night mode which is fine for me. Bright enough to see under all conditions.
CanadianGuy
#95
I still have some harness wires should anyone want any. Pretty sure everyone I mailed them to received them. Just pm me and I will drop them in the post.
#96
Share what cameras you guys have used and it's quality.
#98
Thanks CG! My wife wondered who the letter was from. "Oh, this is from your online friends?"
Sent from my VS986 using Tapatalk
same here... I would have never even noticed if no one told me.
