Butterybunz is Back! Let the build thread commence...
jeff
#81
Awesome updates the car looks amazing.
Tell me about the LSD on commute/everyday driving. Worth it or not?
Butterybunz
Butterybunz
Thread Starter #83
Not worth it if your just using it for commuting. No more torque steer with my hybrid turbo, the real difference is being able to put the power down coming out of a corner. The car is glued to the road like I've never felt before.
#84
Damn I'm bad at keeping this thing updated!!!
Recent Mods:
Quaife LSD Installe! Thanks to my friend VirtualRonin & a Ford mechanic friend of mine.
Tarox 6-Piston BBK with Track Pads
ADV1 ADV5 Track Spec 3-Piece Forged Wheels W/ Titanium Hardware & Lugnuts
245/35/17 Toyo R1R Tires
Euro LHD Headlights W/ VirtualRonin's Wiring Kit
Diffuser Fins
Big Mouth Snorkel
Pierce Motorsports Bracing
I'll try to get some better pics. These are from my cell which is pretty dated.
First track weekend is early June, I'll get to test the LSD on track [rockon][/QUOTE
Havent heard from you in a while....its always good to have a fellow 'Sota boy In the joint! besides me and Ronin an a couple of others....[thumb]
Butterybunz
Butterybunz
Thread Starter #85
Yeah man, Ronin is the best. He was a huge help with my LSD install.
#86
^^^THIS is why I want one, YES, even for street driving on the factory snail/power. ;) [driving]
(NOT for straight line acceleration/drag race purposes!)
#87
If you don't mind, explain the concept of your hybrid turbo.
TDavis
#88
I need to invest in one of these. I noticed coming out of a corner at my track day that it kept hesitating going WOT out of a corner.
Butterybunz
Butterybunz
Thread Starter #89
A hybrid turbo is when you take a stock turbo housing and upgrade the internals of it. There's a few options on the market, I'm using a Pumaspeed X37. The X37 spools almost identical to stock but has much more top end power. On E30 fuel I'm around 280WHP.
That's your traction control / stability control cutting power. Turn that off and the car will get wheel spin and pull to the outside. With the LSD it just grips and shoots wherever you're pointing the car.
Butterybunz
Butterybunz
Thread Starter #90
TDavis
#91
Oh it was fully off. You could tell one wheel was spinning.
Butterybunz
Butterybunz
Thread Starter #94
Minnesota Cars & Coffee
First track event of the year: Proving Grounds @ Brainerd International Raceway
A little AutoX 3-Wheelin
#95
Question: for the front's did you have to trim any metal (other than the fender)to fit the new 245/40/15 setup? I'm still getting rub on a bracket where I assume the crash bar goes to the apron. I also trimmed the one tab where the bumper meets the fender
Butterybunz
Butterybunz
Thread Starter #96
No I did not, just cut the fender. What size tire are you running?
#97
Running a 215/40/17 (technically a 225/40/17 as in runs a size larger) Maybe I'm just too low in the front
Planning to go to a 15x8 +20 with a 225/50/15
Butterybunz
Butterybunz
Thread Starter #99
I run 245/35/17 for daily setup (same diameter as stock) and did experience very slight rub on the flares during track use. My new track setup is 245/40/15 with is an inch smaller in diameter and have absolutely no rub.
