New Tarox 6-Piston FiST Big Brake Kit option!! 300mm, may clear OEM wheels!
Quisp
#61
Hey guys. I just completed my first track day on these brakes. On my way home I noticed I'm getting pulsating vibrations from them whenever I use moderate braking now. Any ideas? I took them apart today and the pads/rotors look okay.
Try scotchbrite pad and brake clean on rotors.
Perfblue15
#63
They clear 15" [woot]
My new track setup. 15x9 ET20 Rota Grid Concave W/ 245/40/15 Hankook RS4s
How much clearance do you have between the calipers and wheel spokes? I'm debating whether I wanna try these with my 15×8 TD 1.2s.
#64
THAT wheel/tire setup is INSANE!! [twothumb] [driving]
Do they make those in a 15x8, 4x108 and a more factory fender friendly ET? (BTW; the white wheels in that spoke pattern/'concaveness' look GREAT!!)
Butterybunz
#67
I test fit 15x8 TD 1.2s just to see if the Tarox calipers could fit inside the barrel of a 15" wheel and they did. They would not have cleared the spokes without a 10-15mm spacer.
You'd have to check. You can also do group buys and order custom sets with your desired specs, that's where these wheels come from.
Dunno if you've already said so but how'd the Tarox's do on the track?
They performed okay at my first track day, I'm going to give it 1 or 2 more track days before I give my full review.
Where did you get the wheels?!
I found them on eBay. They were custom ordered and this was a remaining set from the custom group buy.
Perfblue15
#69
Thank you for the response I'm out of room in the fender well as is. These are definitely not an option for me.
#71
Do the Tarox come with Dust seals to run them as DD?
PunkST
#72
May i ask what flare setup that is?? Been wanting to run fox body offset and width wheels since i bought the car.
