Coolant leak, trying to find a solution
Trying to figure out a solution to find the little culprit of my coolant leak.
It's dripping from above the metal cylinder where you can see the orange droplets, what is that cylinder?
still looking online to find a diagram of the ecoboost engine.
any advice?
Looking to solve this issue on my own, the dealers around me have a bad reputation.
any advice?
The cylinder is your AC compressor, above that is the thermostat housing. That is more then likely the coolant leak issue. Could also be a loose lower radiator hose that connects to the thermostat housing, there are a few different
coolant hoses down there though. Hope this helps.
D
Deleted member 2208
Guest
I had a similar problem. Orange staining, a slow coolant loss. Yet could never find where it was leaking.
A pressure test showed a pinhole in the upper radiator hose that I could never see-hot or cold.
How many miles on the car, and what age was the car when this occurred?
felopr
probably the lower hose, is going to be a pain to remove it fyi
D
Deleted member 2208
Guest
32,000 miles, 1.5 years old. 2015 ST
That was 28,000 miles and 1.5 years ago.
WOW, I may be getting those Whoosh or Mountune silicone radiator hoses A LOT sooner than I was planning on doing.
SteveS
Considering I see liquid drops and dried marks on the hose in the upper right, and in the lower left foreground there's a lower hose and clamp, I'd suggest the clamp in the foreground is the source, spraying upwards and hitting the compressor and the other hose.
