I typically use a bigger oil filter on most of my cars. Back when I owned my 225 Audi TT I used what they called the "Big Kahuna". I was searching around I know stock uses FL-910S. A step bigger above the 910 is the FL-400S which mountune suggests. While searching for a larger filter I cross referenced FL-400s on WiX's website and the WIX 51516XP came up ( xp being extended performance). I was googling around for the WIX filter and turns out the mustang eco boost guys use this WIX filter instead of their FL-400s to help increase oil capacity and dwell time. I'm no oil expert but I do believe in running the biggest filter possible, helps with increase filtration media, increase oil capacity, and dwell time.
Normally I use the FL400s, The 910 Shown was installed on previous oil change as I had it laying around.
Comparison between FL-400s and Wix51516XP
Fitment / clearance. Mind you I have a custom oil cooler set up / sandwich plate.
If ya'll were wondering the "Big kahuna" is shown below on the left.
