GB Group Buy #2: Euro Headlight DRL Wiring Harness Kit
Trader history for VirtualRonin (1)
VirtualRonin
VirtualRonin
Military Veteran
Ajo, AZ
Thread Starter #24
I think that is the seller I got my lights from. They were DEPO brand but the RHD are wired the same as OEM lights.
That's right, I forgot about that. I'll make a note of that going forward.
Thanks for the reminder!
VirtualRonin
VirtualRonin
Military Veteran
Ajo, AZ
Thread Starter #27
Disregard I just seen where I was added Thank you!!
No problem. Are your headlights RHD or LHD? The wiring differs between the 2 styles
Evans
looks light right hand Drive would be the easiest to find. So I guess put me down for RHD
VirtualRonin
VirtualRonin
Military Veteran
Ajo, AZ
Thread Starter #30
I think you can find the DEPO (LHD) brand on eBay. Whoosh Motorsports sells the Ford OEM Euros (LHD) here stateside.
Any RHD model will need to be retrofitted because the light cutoff pattern is different, FYI.
Evans
Ill find a set of LHD DEPO Brand so put me down for that wiring please sir!
Tucson
#35
Sorry, can I trouble you to update my order please? Whoosh no longer has the OEM Euros available, so I'll be ordering the Depos from eBay. Thank you!
VirtualRonin
VirtualRonin
Military Veteran
Ajo, AZ
Thread Starter #36
Not a problem.
Be sure to order the LHD model, you have to do a retrofit if you buy the RHD model.
VirtualRonin
VirtualRonin
Military Veteran
Ajo, AZ
Thread Starter #37
3 days left to get in on the group buy!
July 1st is the cutoff date
VirtualRonin
VirtualRonin
Military Veteran
Ajo, AZ
Thread Starter #39
Hmmh. Whoosh currently has no European OEM headlights in stock, or he can't get anymore?
Not sure, have you contacted Ron@Whoosh?
