Poor dyno run Mountune MR230
Hey guys, new guy from Oz. Took my car in for its first dyno.
As you can see i only made peak power of 110kw at wheels!
I had calculated i should have closer to 140!!
That number is worse than stock.
I have the following mods
Whoosh 3"catted dp
Custom 2.25 ss exhaust
Ceuk C Perf FMIC
Whoosh hotside pipe
Whoosh crossover pipe and turbo elbow
Velossa Tech Big mouth intake
Ramair induction hose
Vudu short shifter
AWR Rear motormount
Gfb diverter valve
Mountune airbox with KN filter
Mountune symposer delete
Mr230 tune w handset
I am completely confused, my boost reads about 21.5psi and car feels fine.
Any ideas? Torque numbers look okay?
Sent from my SM-G970F using Tapatalk
FJ16
I don't know what boost numbers that kit should be hitting, but 21 seems a little low (my Dizzy tune hits 26+ on stock turbo).
I thought it had an MRX turbo in it... I apologize! Should be good to go after the tune is loaded.
FJ16
Boost/ charge hose leaking....calling it right now.
Im thinking that's a good guess; it's what my money would be on. On the plus side, if it's been leaking for a while now that car is gonna feel GREAT after it's fixed.
It would be helpful if the dyno had the RPM where the max Powers were made. You are getting 300 lb of torque but at what RPM.
Would you still make 300 pounds of torque with a boost leak?
gtx3076
Car looks like it got very rich halfway through the pull. Looks like 10.5:1 but hard to read that graph.
EDIT: Mainline dynos are load based like mustang dynos. They will usually be much lower compared to dyno jet (inertia based). Your numbers looks similar to mine using the mustang dyno correction factor of .09 on vdyno and I'm stock on E30. I suspect a pro tune would net you better results assuming you have no hardware issues.
jurule20
Whats the best way to find a leak?
And yeah could i be making 330 torque with a boost leak???
Thanks for the replies
jurule20
Thanks for the reply. I have the locked MR230 mountune tune
jurule20
I also did a 0-100kmh test last night and did 7.2 secs which is a mile off the supposed claims of 5.9.
[emoji24][emoji848]
gtx3076
Best way to check for leaks is first a visual. Check all your clamps, and any obvious signs. Then if it still doesn't seem right, you can buy or fab up a boost leak tester, where you disconnect and plug the intake and apply a safe amount of compressed air to the system and listen for any hissing and use a bottle of soapy water to spray and look for bubbles.
Looking at your graph again it seems like your power drops off pretty dramatically around the time you start running rich (too much fuel, not enough air), so I could see a boost leak being the culprit, or there's something wrong with your tune.
jurule20
Another thought, couple weeks ago i installed an alloy crossover pipe and turbo elbow. Fitment was a little off but if one of the silicone pipes arent completely sealed could this be a point of boost leak at higher rpm, so torque is fine lower down but at higher rpm it starts leaking boost giving me this lower peak power?
XR650R
It's possible.
jurule20
Thread Starter #18
The turbo elbow didnt have a gasket, im gonna put the stock one back on. Was a much better fit also to the silicone coupler.
Fingers crossed this is my leak point.
shouldbeasy
I used some RTV (Permatex Ultra Grey) on my inlet elbow as it was just a flat metal on metal surface. Just a thin bead as it doesn't take much.
As someone pointed out in a prior forum thread there is no boost until after the turbo so that cannot cause a boost leak.
