Turbo Technics S280 Turbo Kit Dyno, Virtual Dyno, and Datalog Thread
Yeah most likely he will just further adjust ur fuel and ur charge temp compensation tables. I was getting alot of knock up top even in colder temps and my charge temps were shooting up 20+ degrees. May switch up my intercooler at some point (whoosh v2).
Quit playing....just get the Bravoalpha already.
JDG
JDG
Conshohocken, PA
Thread Starter #23
Revision v7 w/ aux fuel (93 octane)
The spool is insane. AFR look much better but still seeing knock. Need to investigate this BA intercooler.
JDG
JDG
Conshohocken, PA
Thread Starter #25
looks great! you think the knock is from heat?
I think it’s a combination of the added heat and not enough octane. The knock will go away on ethanol I’m nearly sure.
@MagnetiseST sent me a log and with the BA intercooler he sees an 11 degree rise in charge temps. I see about a 15 degree rise during a similar pull. He is in Florida though so definitely an improvement over my FMIC.
wetwea33
langhorne
I think its mostly just the octane at this point. We're both at the limit of 93. It stinks these cars really don't like pump gas but it's a low displacement motor that's not super high in compression so you have to run a ton of boost.
JDG
JDG
Conshohocken, PA
Thread Starter #39
Back on topic. Nearly complete for 93 on 4-port aux fueling. Took a bit of boost out to control knock. This revision has virtually no knock. v8 Aux VDYNO.jpg
Tucson
#40
Curious on whether my tuner will pull boost or pull timing. I am hoping to run 30psi.
