SWAVE Summit Chassis Handling Products available in the USA @ whoosh
The back one that has six points is the one I have my eye on.
kivnul
Looks like it is not compatible with the Pierce 4 point. I made a bastardized image to show
The two center bolts are directly under the pierce bar.
The one solid brace 6 point Pierce style would be nice in that low profile design though.
How much you are charging for the chassis braces?
ron@whoosh
ron@whoosh
Vendor
Thread Starter #25
we're loading all the product range this week
whoosh will be offering SWAVE's full range for the Fiesta, Focus ST/RS and Mustang so there is quite a bit of product to cover.
I'll prioritize Fiesta as usual though haha
Sweet can’t wait to drop some tax money on the fist! Lol
How will they fit with the Hotside pipe that is non factory or ATP?
ron@whoosh
ron@whoosh
Vendor
Thread Starter #28
I'll test with cp-e / Mishimoto being 2.5"
ATP, whoosh, MBRP, Peron, Turbo Technics all use OEM size (1.75") or 2" pipework which clears no issue
Sekred
I am using a EFR turbo (Peron kit). I had to modify the mounting for the hot side charge pipe. What I did was remove the studs where the pipe bolts to the rear of the sump and use bolts. This raises the pipe about 1/4" of an inch. I also bent the bracket on the charge pipe to raise it a little further. This involved cutting part of the bracket and bracing it.
Look at the image I posted before get some idea of what I mean.
Any update on the chassis braces? I don't see them on the site yet and I'm interested in pricing.
I'm interested in these. Anyone using them right now care to chime in with thoughts?
#33
NOPE STILL M.I.A. ...Ron@ whoosh is awaiting the shipment as far as I know.
#37
Getting antsy - how much clearance does this gain say over similar products from TB?
If it's negligible, I'll likely go with the cheaper TB Perf products as I know SWAVE is pretty proud of their products.
#39
I was considering both and the design of the TB 4 point kind of leaves me wanting. The SWAVE is better. The problem with SWAVE is they are really hard to nail down and deal with even UK shops a lot supposedly stocking according to SWAVE do not have product in stock. I would probably have one now otherwise.
#40
I am hoping for the Woosh version Ron will materialize before swave ships. You know he will eventually have a Woosh engine block in the works. :)
