Sakel's clean build 2017 magnetic
Sakel
Jacksonville
Thread Starter #104
A few minor changes, I peeled off the old decals, my custom ones are in. They ended up a little small, but I like them. It matches the theme with my license plate now! IMG_20200730_014154_782.jpg IMG_20200730_014227_291.jpg
Sakel
Jacksonville
Thread Starter #106
Seemingly without warning today my car was completely dead, no start. Luckily my driveway is on a hill so I was able to pop-start it, and when my AP booted the battery was at 10.6volts. So new battery installed, the car turns over much faster now so I guess my battery has been on the way out for a while. Also my front brakes gave up the ghost, so new pads. Car has a little over 65k on it now.
As an aside, how bad is the wait for M2 motoring flares? I graduated college with my BS in manufacturing engineering at the end of July.
shouldbeasy
Calgary, AB, Canada
They don't make them anymore.
I waited 8 months with nothing to show for it.
Sakel
Jacksonville
Thread Starter #117
I hope that this is a comparison of old to new* [wrenchin] Those are still good! You still have the backing plates to grind down too!
it is! They didn't make noise until I had to do a panic stop, then all hell broke loose. There was friction material left, but only just
shouldbeasy
Calgary, AB, Canada
I waited for the noise - turns out the noise I heard was the metal backing plate!!! I had used up ALL of the pad... First time for that one!
Sakel
Jacksonville
Thread Starter #119
Did some more maintenance today, I still have an oil leak from the turbo drain. The oem turbo used M6 bolts and the MRX uses M8, and since one of the step studs broke I decided to modify the oil drain pipe. I drilled the flange for the larger bolt, and modified the gaskets. Now instead of studs I have M8 screws going directly into the turbo. It worked great but leaked, so today I added a new oem gasket and some permatex. Also while under my car I got a picture of the 2 point brace, it has taken a battering. It's bent up a large amount in the middle, but other than 2 dings in the resonator the underside of the car is in flawless shape.
