Isabella de la fiesta
R
Rocketst
Chesapeake, VA, USA
Thread Starter #444
Is it possible my redline at 7750 is too high for the turbo... Cuz it feels like up top it's running out of steam. Idk if this spring will fix that but I know ethanol makes more gas.
Sent from my IN2019 using Tapatalk
Se7eN
San Juan, Puerto Rico
I wish I could post a meme sticker, don't spin it above 7000 even if the rev limiter is so high. Unless you are forged and have cams.
He is Both Mountune Mrx block and Stage 1 or 2 cams*
I'm sure though that when you got cammed it moved the engine Redline up a couple notches. Like I'd bet it would be 8k.
Looked at their website it says PowerBar on v2 is 2k-7k. So it is a possibility *
R
Rocketst
Chesapeake, VA, USA
Thread Starter #452
So new noises... A low pitched wooo coming from the engine bay while boost is still under vacuum... When I get on it it goes away. Turbo may be going
R
Rocketst
Chesapeake, VA, USA
Thread Starter #453
Could potentially be a boost leak but idk. I'm taking the turbo out for some upgrades soon so I'll be checking for shaft play and seals
wetwea33
langhorne
Get rid of the pumaspeed turbo and put a real turbo on the car and actually take advantage of the built block and especially the cams.
Sent from my SM-G781U using Tapatalk
R
Rocketst
Chesapeake, VA, USA
Thread Starter #455
If the turbos actually fucked, I'm considering upgrading to a borg warner 7670 twin scroll with a 1.02 ar and externally wastegating it.
R
Rocketst
Chesapeake, VA, USA
Thread Starter #456
New accessories in route. Garrett 660 peron kit, new uprated hpfp, bravo alpha lpfp, uprated injectors, new map sensor(5 bar). Gonna need more traction. Hit me up with known good ideas for increasing width of tires. Not a huge fan of flares so would prefer a different option.
R
Rocketst
Chesapeake, VA, USA
Thread Starter #457
Does anyone know, if I weld in a cat to the thermal I have and move the 2nd o2 sensor past it extending the wires and such, will it still give a good reading?
R
Rocketst
Chesapeake, VA, USA
Thread Starter #460
I think the turbos just too small man. I never saw any issues when I took the system apart.
