Blue track/street build - salvage restoration
J
Jabbit
Thread Starter #103
Pretty sure my turbo is blown, car will be out of commission for a bit as a wait for an s280 in the mail.
the new hybrid turbo is toast? how did that happen?
J
Jabbit
Thread Starter #105
This is how it sounds when driving -
View: https://www.youtube.com/watch?v=m-Z2lsjmDLc
Was an absolutely ripper while it was good. I'm past the age to be swapping turbos so I had a shop do it. Consequently I'll be having a shop to the remove and replace but not until next month. It drove like it had 30 horsepower. Not even like it just had no turbo but like it was actively really far down on power. I'm operating under the assumption of seized compressor wheel.
well that stinks. I’m assuming you’ll be able to get a refund on the turbo?
Wasn't this one of Tygen's first prototype hybrids which he sent you to test/try?
Did you have to lay out any coin for it, besides installation labor?
J
Jabbit
Thread Starter #108
I'll keep my turbo issues or perceived issues out of this thread for now. The turbo has not been pulled yet to make a true assessment of what did or didn't happen.
Fair enough.
I was NOT speaking against Tygen whatsoever, in any way, shape, or form, as finding any flaws/problems that need to be addressed (yes, of course that is even IF it was actually the unit which caused the problem) is the whole point of real world testing/trials in the first place. [wink]
J
Jabbit
Thread Starter #110
Fair enough.
Agreed, that's a great perspective to have. I consider everything that has happened up to this point valuable and informative.
Tygen ain't no Frankenturbo* that's fo sho!
I wish I was closer to Jabbit, to help diagnose. However we will have to wait a little to see what has happened.
M-sport, you are correct, this is the purpose of this process and is needed before larger scale production.
Jabbit has been great to work with!
J
Jabbit
Thread Starter #113
Before and after. Whoosh 16" kit, extended H&R studs and 10mm spacers, and ISC coilovers with uprated springs and dampers. Going to switch to Muteki open lug nuts.
This has me wondering if Ron's 15"/285MM rotor kit will fit under my 15x7, ET48 Method MR501VTs without any spacers. [dunno]
J
Jabbit
Thread Starter #115
Pretty sure I could go down to a 5mm spacer. Going to try it.
J
Jabbit
Thread Starter #116
If you are curious, this winter I'll mail you a caliper and bracket and you can test fit.
