haste
Strongly considering upgrading my taillights for the spec d leds. Do you have any pictures directly from the back with them on and with brakes engaged? Interested to see how they look from the bake and how much brighter they are. Car is very clean btw. 👍
I was disappointed with the brightness of my spec-d taillights. The turn signals are especially weak.
anticon
Finally pulled the trigger on a whoosh hybrid just now. While it wont get installed until next spring, this will give me some time to see if I want to do a ported mani and milltek dp to go with it as planned, however its been suggested those two items arent as big a deal with a hybrid. I am also going to do a little research into which wastegate to grab. I'm leaning Tune +.
I'm currently tuning the Whoosh hybrid that I bought used. I have the 11 psi Turbosmart and the GFB DV+. I also have stock manifold and downpipe. I'm only on my second revision of the tune but the results are promising.
akiraproject24
I'll try to keep an eye on how the process goes for you and let us know what your end results are. I have the lifetime tune with Adam so I'll be doing 93 and E30 with him.
New wheels are finally coming in soon. I’m thinking of DIY ceramic coating them. Does anyone have any brand recommendations??
I use GTechniq C5 Wheel Armor. One bottle is enough to do two coatings on four 17" wheels including the barrels.
Application is simple. You receive the applicators in the box along with nitrile gloves. Which you will want to wear. Apply in a well ventilated area. You can do the face of the wheel, then the barrels. Then remove. You will need a couple of microfiber towels for the removal.
I would also suggest washing the wheels first and then wiping them down with Eraser, GTechniq Panel Wipe, or an isopropyl alcohol.
I have my OZ Superturismos coated, the wheels and calipers on my GT4, and the wheels on the Cayman T. By far, the Fiesta has the most mileage on the wheels and they take the biggest beating. The coating has held up very well.
There are other products and you could apply a standard nano coating. Wheels coatings are typically designed to handle the heat more effectively.
Pretty cheap compared to other coatings I’ve seen. I’ll give it a try!
After 4 months of driving around with a hole in my roof after my sunroof broke on a canyon drive, finally got around to fixing it permanently with a aluminum panel, some rivets and adhesive. Scary drilling holes in the roof, the inner sunroof reinforcement is annoying to deal with as well, there were a couple holes I had to redrill due to hitting metal that was too thick.
Also did my Coolerworx shifter, only issue I had was muscling it into position once the shifter cables had been attached. Haven't taken it for spin yet (adhesive on the roof is still setting) but looking forward to doing so tomorrow and beating on the car at Chuckwalla this weekend.
#racecarlife
Sent from my IN2025 using Tapatalk
Washed it....then got coaxed to drive to a state park. Then there were dirt roads....That really toasted and Burnt my bagels. But got to pick apples with the BAE and the meatball.
Sam4
I'm reminded of Cousin Eddie from 'Christmas Vacation" - "Ain't never seen a pair on a dog like that before Clark?"
His finest work of....Drop down and get your eagle on.
Jabbit
#racecarlife
Did you pull out the glass/motor/etc from the sunroof? Curious on the total weight of those parts. I've been planning to do the exact same thing as you've done.
#racecarlife
I am now soooo glad that I opted to order this car without that big hole in the roof. [wink]
Yeah I removed it all, glass, motor, rails, headliner. Unfortunately don't have those components anymore to weigh them, it honestly didn't weigh that much. I'd estimate total of components being around 40 lbs? But anything helps in the quest for lightness.
Technically the car I 'bought' didn't have the sunroof, the only option I wanted was the black wheels. But I bought it sight unseen from the sister dealership of my local dealer, and they were gonna bring it north for me to take delivery. I get a call from them an hour later saying 'hey somebody was buying that car down in the other dealer right as we were signing papers, but we have this other one that's the same spec but has sunroof and nav and we'll honor the same price." So I couldn't really say no to that. And there were times I enjoyed having the sunroof, but it was always the ultimate plan to delete it.
40 lbs up high is a lot for roll center.
Business6
Sunroofs are, unfortunately, a huge liability all around. Water intrusion, mechanical failures, human ejectors, etc.
If I keep this long term I'll seriously consider doing the same thing.
I disagree, I think they're just fine! [thumb]
Thank you! And you got it:
Turn Signals:
Brake Lights:
^^^^(Also noticed my third brake light is out, which means the Clear LED 3rd Brake Light upgrade from @ron@whoosh just occurred. Now I have a good excuse to also install my 3rd Brake Light Flasher Module while I'm in there! :geek:
Also, my Super Bright Ebay "Luyed" Brand 900 Lumen LED Reverse Bulbs: [twothumb]
I ordered the Mountune Triple Pass Radiator back in late June and it finally arrived today from backorder! [clap] And just in time for Fall! :ROFLMAO:.....though to be fair it is still hot as hell down in Phoenix so I will get to put it to the test before it gets cold here!
It really is a shame that this is completely hidden once installed, it's functional art! :love:
