cmb5286
Don't even have it yet, but bought a couple low buck things. New shift knob, Lamin-x film for the fogs, and a Cravenspeed stubby antenna. Nothing performance related whatsoever.
Magnetic
Put on a new cabin air filter, wasn’t that bad, thing looked like it was replaced before, thing was hard as a rock
How involved was it to replace. I never have changed mine since I got it in 2016.
Magnetic
Tested out Weather Tech's FiST sun visors. They are Legit. All fit absolutely perfect with the exception of the front windshield one that has a slight crease but doesn't affect functionality. Take a look. The 4 corner triangular small windows dont get a visor but the big all 5 other windows do.
This is a MUST in AZ with 120+ degree weather. Highly recommend.
I also had made a sort of shade to block people from seeing my hatch subwoofer since I removed the upper rear seats. (Last 2 photos)
Outside
Inside
Subwoofer Net Hider. Went to The Home Depot and got some simple screening and screwed into the hatch cover.
You have to pull off the passenger side console trim, which is easy to do. Then you pull screws to gain access to the filter. One of the screws is absolutely a pain. So much so I didn't put it back.
Removing the filter isn't a problem, as you don't have to worry about damaging it. Inserting the new filter requires technique and patience. A couple of YouTube videos showing it and I would absolutely watch those first.
Reckon its about time for an update! [thumb]
Did an oil change at 20,500 miles.
Then I went for a spirited drive(after getting the fresh oil up to operating temp) and stopped for breakfast with the FiST at my local favorite coffee shop called Method Coffee. [driving]
I recently picked up a very gently used OEM Ford FiST Car Cover from @Woods247 for a great deal, so this is my car's Halloween Costume for the year! :alien::geek:
Even more recently, I've been out of town for work on the East Coast for the past 10 days. When I walked into my office at work this morning, it looked like Christmas with all of the boxes waiting for me! :ROFLMAO:
First up, I picked up a PJ1 Air Filter cleaning kit to keep my ITG Foam Air Filter properly serviced.
The main reason for this, is I forgot to clean my ITG air filter in the last 7,000 miles. :LOL:
I also picked up a spare stock turbo that was removed with only 3K miles for a deal that I couldn't say no to! I'm planning on keeping my car forever, so I'm starting to hoard parts for it while they're cheap and easy to find. :LOL:
Also ordered a couple of goodies from @ron@whoosh that came in super quick! (y)
Whoosh Hot Side Intercooler Pipe:
Ethanol Test Kit since I just recently ordered an E40 Tune from Randy at Tunewerks:
As well as a Ford OEM Clear LED 3rd Brake Light and 2-pin eBay harnesses so that I can make my 3rd brake light relay flasher reversible. ;)
Ron was kind enough to throw a sticker and this banana flavored wafer into the box with the parts as always! :geek:
Oh, and to compliment the Whoosh Hot-Side Intercooler Pipe, I also picked up a set of Mountune Intercooler Hoses on eBay for a great deal! I thought I ordered them in black, but blue showed up, so blue it is! [poke]
Decided to give this 30mm Accelerator Pedal Spacer from Garageline a try to see if it makes heel-toe braking easier when I'm out canyon carving. :cool:
Lastly, my FiST Sweatshirt from Blipshift came in just as cold temps set in here in Prescott! :ROFLMAO:
Today was a good day. :)(y)
akiraproject24
I grabbed those same boost hoses. I was irritated at first about being blue but for the price and the fact that they aren't overly visible I eventually relaxed about it.
It must be soooo nice to be able to do that (or spend 8 hours+ at a time with the car up on jack stands/ramps to swap in an aftermarket intercooler/radiator, do a brake job/bleeding, etc.) without looking over your shoulder for any HOA Gestapo agents itching to fine you BIG$$$ for working on your car in your very own driveway!! [wink] [thumb]
